Title: Dan: S1 Wiring Post by: FieroBUZZ on March 21, 2004, 08:03:53 pm After holding up the loom, etc, there are a few wires to adjust in length. I think that there will only be a bit of extra length if I mount the ecm low behind the passenger seat. This means that by enlarging the hole in the f/w, I can use the Bonneville grommet and keep that big square connector. In other words, I ain't cutting all the wires. ::)
On a more somber note, I found a hole in my block (or intake) that I can't account for. I'll post a pic later. It's round, so I'll assume it's either an inspection port or a frost plug hole. Gary Title: Re:Dan: S1 Wiring Post by: FieroDough on March 22, 2004, 08:21:32 am Hey Gary! I still want to get that wiring harness fabrication on tape! let me know when you are ready. :)
Title: Re:Dan: S1 Wiring Post by: 2ML67 on March 22, 2004, 11:46:47 am Would have to see the hole to be sure but if its round look for threads inside or a ring that would seat an o ring of some kind. If you want to wire that way then we will make the firewall hole large enough and bury the other connector inside the console. That way you have an easy way of removing the harness with the engine for future mods when you get tired of a mere 205hp. The same should work for purple when he gets tired of 206hp. I suggest we pick a nice warm weekend and finish off your beast. Get the exhaust figured out and we can finally instal the whole thing at once.
Next time I will bring my van that way I can also bring along lots of tools and such. Title: Re:Dan: S1 Wiring Post by: FieroBUZZ on March 22, 2004, 12:14:27 pm Here's the hole. It was tucked in under the egr and crossover pipe. I can't remember if there's a big vacuum line around there or not. Also don't recall if that part is open to the clutch/flywheel area. The hole is smooth all the way through.
You don't remember Brian practising with the drill do you? ;D May I sugest a small text document with various series 1 slurs in it. That way you can cut and paste rather than type them each post. :-X Title: Re:Dan: S1 Wiring Post by: GoFast85 on March 23, 2004, 10:49:04 am Did I miss a part that I should have drilled? ;)
Title: Re:Dan: S1 Wiring Post by: FieroDough on April 01, 2004, 01:52:16 pm Hey Dan!
When would you like to go ober the Series I wiering and the Series II wiering? I can then put it on tap. If you are really camera shy i can tape myself after. I just want to make sure you get the credit for your work, cheers! Eric |
