Title: Front mount battery tray Post by: aaron88 on March 16, 2005, 06:53:38 pm I have one of these sitting on my shelf. Does anyone want it for $45? Or $80 installed with terminals and wire, maybe more depending on the shape of your car).
Aaron . Title: Re: Front mount battery tray Post by: Rob on March 16, 2005, 10:05:01 pm this goes in the front light well?
comes with cable and all? Title: Re: Front mount battery tray Post by: FieroBUZZ on March 16, 2005, 10:11:56 pm I'll take it Aaron! I already have a hole cut >:( I have cable, etc already. (I don't mind if you'd like to give Rob first shot)
Gary Title: Re: Front mount battery tray Post by: Rob on March 16, 2005, 10:32:41 pm no worries, its all yours!
Title: Re: Front mount battery tray Post by: 2ML67 on March 17, 2005, 10:37:12 am There not that hard to make Rob so I can do one in your car when I put in the 3800SC for you. Or buy it of Aaron and I can intsal it for you. $45 is a good price for one, it frees up a good spot to mount the ignition module and charcoal cannister. Dan
Title: Re: Front mount battery tray Post by: aaron88 on March 17, 2005, 11:57:32 am I'll take it Aaron! I already have a hole cut >:( I have cable, etc already. (I don't mind if you'd like to give Rob first shot) Gary If you already have a hole cut it's probably too big. You might have to wait until I have time to make one to fit. What are the dimensions of the hole and is it square? Aaron P.S. The tray doesn't come with cables and terminals, that is $24 extra on top of $45. Title: Re: Front mount battery tray Post by: FieroBUZZ on March 17, 2005, 02:39:34 pm The hole I made is 9 3/4" front to back and 9 1/2 wide. I was going to make a fiberglass box. I guess I'll just continue with my original idea. Thanks.
Title: Re: Front mount battery tray Post by: aaron88 on March 17, 2005, 06:09:23 pm The hole I made is 9 3/4" front to back and 9 1/2 wide. I was going to make a fiberglass box. I guess I'll just continue with my original idea. Thanks. The size I recomend is 9.75 back to front and 8.25 side to side. Your hole is a bit wide but it should work as long as it's located properly. If your not in a hurry I could have a look at your hole and make up a proper fitting tray. But I can't guaranty a time line on that (form what I hear and see, that should be fine with you). Aaron . |
