Title: 2.8 problem Post by: lsixtyseven on August 24, 2007, 07:12:21 pm My 2.8 won't rev above 4000 rpm under load, but will in neutral, anyone have any ideas? Tried going up a steep hill today almost didn't make it.
Title: Re: 2.8 problem Post by: c-l on August 24, 2007, 07:24:37 pm Hey Tibs,
Mine did that a few times in the last 20 years. It starts like that and quickly gets worst. Both times, the problem was traced back to a clogging catalytic converter. Easy test - open up your exhaust past the Y pipe, put on a good set of hearing protector and go for a ride. If you can go over 4000 rpm... I'd take a good look at that cat ! Title: Re: 2.8 problem Post by: FieroBUZZ on August 24, 2007, 07:30:34 pm Or hit the cat from underneath to see if it rattles. If it's fairly old, it wouldn't hurt to change it. No more etesting so I guess you could hollow it out if you wanted.
Title: Re: 2.8 problem Post by: lsixtyseven on August 24, 2007, 07:37:24 pm I'm going take a look at the cat, i hate cats. ;D
Title: Re: 2.8 problem Post by: lsixtyseven on August 24, 2007, 07:42:09 pm Does anyone know the size of the exhaust pipe?
Title: Re: 2.8 problem Post by: dguy on August 24, 2007, 09:45:06 pm 1 7/8" inside diameter.
Title: Re: 2.8 problem Post by: lsixtyseven on August 25, 2007, 05:13:27 pm Well it seems that the cat was the culprit, the car never ran so good and loud. O0
