Title: rims / tires Post by: 88formula on May 05, 2010, 06:35:50 pm as i have finally decided to keep my fiero, i'm thinking about rims and tires.
and the question is, would 17"s look just rediculous? and what is the max width i can go for both front and back Title: Re: rims / tires Post by: dguy on May 06, 2010, 06:16:08 am Ridiculous is in the eye of the beholder.
The maximum tire width which will fit on the stock suspension depends upon the width and offset of your wheels. I have no experience with 88s, but on the pre-88 models a 255/40 tires on a 17" x 8" wheel with +35mm offset leaves about a finger width of room between the inner sidewall and the strut. No issues at all with 225/45 (same wheel) on the front. There's a good reference thread on PFF which may help you out. Click here (http://www.fiero.nl/forum/Forum2/HTML/073859.html). Title: Re: rims / tires Post by: 88formula on May 12, 2010, 09:13:14 pm so i got some 17s from tirerack, i must say i'm impressed. Considering i bought this car with 4 different tires, mind you low quality, the ride performance is immaculate. plus i must say it looks amazing.
does anyone by chance have a spare pontiac logo for just behind the doors? mine fell off Title: Re: rims / tires Post by: dimeadozen on June 22, 2010, 01:10:32 pm Looks nice.
Title: Re: rims / tires Post by: montrealcarlo on June 23, 2010, 10:13:29 am ever consider 18 inch wheels. im going with that setup with some xxr wheels.im going to go with 18x8.5 all around
Title: Re: rims / tires Post by: falcon_ca on June 23, 2010, 10:30:51 pm These are 17 x 7 rims with 215/45R17 tires on a modified Formula.
Car is lowered 1 inche and a 12 inches Big Brake kit is installed. Adjustable coil over at the back. (http://lh3.ggpht.com/_m72_QDJWnWI/S7vCd1oc4tI/AAAAAAAAOlk/yH9BiO-1yNE/s800/02%20-%20Sortie%201%20avril%2010.jpg) (http://lh3.ggpht.com/_m72_QDJWnWI/S7vCYVc-7_I/AAAAAAAAOlY/-TLwlIhgFeY/s800/04%20-%20Sortie%201%20avril%2010.jpg) I made a lot of research on Rims/tires for 88. Here are some numbers: Stock: 205/60/15 15x6 +37mm 215/60/15 15x7 +30mm REAR (adjustable coil over conversion needed): 235/45/17 17x8 +35mm 255/40/17 17x8 +35mm 255/45/15 17x8.5 +38mm 255/45/17 17x8 +35mm 255/35/18 18x8 +35mm 265/35/18 18x8.5 +35mm 265/35/18 18x9 +35mm 265/35/18 18x9 +55mm :o Front 215/45 17x7 ------ +38mm 17 x 7 ------ +40mm 17 x 7 ------ +48mm 17 x 7 ----- +38mm 215/40 18 x 7.5 --- +40mm 225/40 17 x 7.5 ----45mm 18 x 7 ----- 42mm 18 x 7.5 --- 45mm Title: Re: rims / tires Post by: aaron88 on June 24, 2010, 12:11:51 am Your car is looking so good.
I also have done a lot of looking around for rims. Ultimately they are hard to find. In the last 5 years I think I've only come across 6 different sets (4 of them aren't even made anymore) that would work and they were all too narrow in the rear. (I think 7 wide in front and 8 in rear was the best I found) To brake the cycle I'm going with Vette rims. 17 x 8.5 wide in the front and 18 x 10.5 wide in the rear. Funny thing is, tires will be cheeper. Also. for several hundred more you could just get custom rims. Ultimately you are going to spend way more on tires anyway. |
