General => Mods => Topic started by: grandam455 on May 28, 2012, 11:43:11 pm
Title: need advice
Post by: grandam455 on May 28, 2012, 11:43:11 pm
I have a chance to get a front nose from a 85gt will this fit on the 84 notchie,also the rear bumper and the rear truck lid work? Thanks Tom
Title: Re: need advice
Post by: Dan on May 29, 2012, 08:15:43 am
Only difference is the grate on the trunk lid and make sure you get the plastic pieces from under the bumpers so they bolt up straight. Dan
Post by: grandam455 on May 29, 2012, 06:59:54 pm
Thanks Dan I was also given working headlight motors, also gas tank and pump and coolant tubes,and calipers,they are the same? Thanks Tom
Post by: aaron88 on May 30, 2012, 12:06:48 am
All the same except I'm not sure about the headlight motors, but even if they are different they should still work (ie: bolt right in).
It's very important that you get all the underling plastic pieces that locate the outer panels for the body swap.
Post by: grandam455 on May 30, 2012, 08:40:32 pm
Thanks for the advice was not sure if they would interchange but i do like the G.T. front and rear fascia. There is a trans. out of the car will it work to, it was from a 2.8 and i have the 2.5 Sorry about all the Question but he calls everyday telling of parts he found in his barn and i'am not a expert, Again thanks guys for your advice
Post by: aaron88 on May 30, 2012, 10:38:10 pm
Auto or manual?
Post by: grandam455 on May 30, 2012, 11:55:39 pm
It is a auto.
Post by: Dan on May 31, 2012, 07:25:30 am
2.5 and 2.8 used the same auto tranny so it will work fine. Dan
Post by: grandam455 on May 31, 2012, 08:47:38 pm
Thanks Dan,My reverse is slipping alot thats why i needed to know.
