General => Mods => Topic started by: aaron88 on November 12, 2012, 10:16:21 am
Title: Aluminum Cradle
Post by: aaron88 on November 12, 2012, 10:16:21 am
Preview
Title: Re: Aluminum Cradle
Post by: can machine on November 12, 2012, 08:40:07 pm
Any idea of what the weight savings will be?
Post by: dguy on November 13, 2012, 07:03:18 pm
Pre-88 by the shape, I think?
Post by: aaron88 on November 13, 2012, 11:13:37 pm
Universal actually, since the rear control arm and possibly(not sure yet) knuckle are custom.
I'm not sure what the weight savings will be because I didn't weigh the stock components. I haven't actually done any weight calculations.  All my calculations have been for strength and corrosion.  I know what the cradle weighs but I don't know what anything else weighs.
Basically I do custom so I can change anything to match whatever the customer wants.  But in this economy and the tight wallets of most Fiero owners I don't expect to sell many.
I'm going to make a second one for myself that will be considerably lighter though.  Without the exhaust humps and for Northstar/F23 combo.
Post by: aaron88 on November 24, 2012, 12:04:35 pm
Why is it that when you think you have all the kinks worked out something comes up and bites you in the but.
It turns out that fixing the geometry is the really easy part.  Figuring out how to do it cheep is really hard.  I'm having trouble with the stiffness of the knuckle and can't seem to figure it out without replacing the knuckle.  Needless to say a custom knuckle isn't exactly a cheep solution.
Does anyone know of a rear knuckle in existence similar to the 88 rear?
Post by: falcon_ca on December 02, 2012, 12:47:53 pm
Did you read this :
http://www.fiero.nl/forum/Forum2/HTML/120882.html (http://www.fiero.nl/forum/Forum2/HTML/120882.html)
Post by: aaron88 on December 02, 2012, 01:54:50 pm
I saw that, but Heim joints are not street legal, so I'm trying to use ball joints.  Also the 88 knuckle mounting location is a bit high and I will not be using a trailing link.  All the geometry just screams custom knuckle to me.
I also can't expect everyone to just go out a acquire 88 suspension c/w coil over kit.  Not to mention that the 88 rear suspension is, itself way out of date and doesn't track true anyway.
I'm trying to figure this out without making too much stuff to try and keep some of the cost down or I can expect to never sell a kit.
Post by: can machine on December 02, 2012, 02:53:18 pm
Is the aluminum cradle going to be street legal? I'm not sure what kind of inspection/certification you would need to use it legally. Have you looked into that? Or can you just slap a "For off road use only" sticker on it to cover yourself?
Post by: aaron88 on December 04, 2012, 12:24:40 am
The whole thing is kind of a grey area.  There are so many kits and hot rods out there they can't deny something because it was fabricated.  All it has to do is pass the safety inspection.  Lots of aluminum cars out there so I don't see why it wouldn't pass.
Post by: can machine on December 04, 2012, 12:34:57 pm
It seems it is a very grey area. I guess it would depend on who does the safety inspection. If they went by the book the mechanic I think would have to fail it since it is a non OEM part. There are lots of cars with aluminum cradles but they have passed certain design/fabrication standards. You or the owner of the vehicle could be liable if something failed. With that being said the one you are designing could be stronger and more durable that the original one. It's kinda a tough call since this is such a integeral part of the car.
Post by: aaron88 on December 05, 2012, 09:19:07 am
It's a bit more straight forward than that.  There are tons of kits available that have moving parts.  That is where the grey area is.  Moving parts (only the ones safety related) and safety equipment need to be tested.  Non moving parts need nothing passed a safety check.  That's why I'm using actual motor/trans mounts, control arm mounts and ball joints.  Ball joints are from chev 1/2 ton.
My knuckles on the other hand are a toss up.  Even though those west end boys have been selling welded front knuckles and all, they also advertise them as auto-cross (ie. off road use).  One of the reasons I'm looking for something a little more "OE".  That and to keep the cost down.  I'm sure if I did billet aluminum nobody would give it a second thought.
My cradle is more rigid than stock, and stronger.  Especially stronger that all those rusted falling apart cradles.
BTW: I also can make steel cradles using the same fixture so if there is a problem I can pop off a steel unit in half the time.
Post by: can machine on December 05, 2012, 07:34:54 pm
Really? I'm really surprised if what you are saying is true, and I'm not doubting that you have researched this. I would of thought that a piece like the cradle would have to be inspected by an engineer and have some sort of testing done on the welds to ensure it would not fail under normal wear and tear. Interesting and scary to think of what people could by and use on there vehicles.
Post by: aaron88 on February 11, 2013, 10:06:23 am
Control arms.  No bump steer.
(http://i48.tinypic.com/2z9biv9.jpg)
Post by: lsixtyseven on February 11, 2013, 10:49:56 am
Looking good, I like.   O0
Post by: dguy on February 19, 2013, 06:21:47 am
Are those ball joints at the control arm/cradle connection?
Post by: Dan on February 19, 2013, 03:18:07 pm
Any chance the cradle could be built with the front cross member moved further forward an inch or two to give more room for mounting larger engines like the LS4 and for most engine swaps the humps for the exhaust would not be needed unless they are following the stock route or running duals.
Also any idea on a cost for an 88 aluminum cradle. Thanks Dan
Post by: aaron88 on February 20, 2013, 01:03:32 am
Dan;
It's a custom cradle so anything can be moved.  The only thing set is the mounting locations, standard with a bushing delete.  Also I have not recorded the stock 84-87 control arm mounts because I had not anticipated ever replicating the rear bump-steer.
The cradle I'm making for my car also does not have the exhaust humps like this one does.
This layout shows all ball joints but I could easily make a change for rubber or polly bushings.  Although if someone was to do that they might as well just use the 88 rear instead.  Also notable is that I'm using front transmission mounts instead of the rear.  But for my cradle I'm using two cylindrical bushings to mount the transmission.
So everything here works together, and won't work with stock rear suspension.  So the setup comes with: Cradle, Control arms and Knuckle (almost any bearing or breaking system setup you want).
Aluminum or steel cradle, steel control arms, and knuckles, it's about $4500.  Give or take depending on options.  Notably it's designed to work with 250-275lb/in 2.5" ID springs.
At this point I'm not sure when I'm going to have the front end redesigned.  Almost the same as the 88 only with a faster camber gain.
Post by: Fred on March 28, 2013, 09:28:57 am
 :o
I'm sure its worth that much, but I wasn't expecting it. I guess I'll have to save up my money...  O0
A couple of question though:
Aluminum or steel
-If it's the same price, nearly the same strength, what are the advantages of going with a steel craddle if it has more weight and it can rust?
Geometry
-Does this setup corrects all the geometry problem of the bump-steer and the camber adjustment problem?
-Would going with a wider track setup will affect (For good or worst) the geometry?
-What is the difference between this kit and the "Helm Motorsport Anti Bump Steer" kit? (I'm not an engineer so from my knowledge both of them looks the same)
Great Job Aaron! Your stuff is looking great! As usual...  O0
Fred
Post by: aaron88 on March 30, 2013, 08:32:22 pm
Your questions are loaded but I will attempt to answer them.
In this application there is one major difference between the Aluminum and Steel that most people are not aware of.  Aluminum and mild steel have very close strengths but the metallurgy works very differently.  With steel; one simply uses as stronger filler rod to achieve higher than base metal weld strength.  With Aluminum; heating the base metal ruins the temper.  Depending on the alloy you don't get any of it back without an exact treatment process.  With 6061 alloys though you do get a good portion of the strength back over several weeks as the metal age hardens back to about 2/3 strength.  So in general to use aluminum in an application that gets welded, you double the thickness of the aluminum and still end up with weight savings (and anti-corrosion, etc...).  Or you re-quench and temper.
With aluminum you can have a stronger, lighter rust-free alloy.
With steel you have great flexing properties and weldability (You can change stuff and move stuff around without affecting the strength).
The geometry is whatever you want it to be.  Any camber.  Track width is completely compensated for (however make note that I move the knuckle meaning longer axles).  Bump steer is delete.  You can have poly, ball joints or rod ends.
The Helm kit is a bit of a bad idea.  It doesn't delete the bump steer, and it requires a lot of maintenance.  Every time an end gets changed, also requires a re-alignment.  A lot of people that get them end up removing them.  There is only so much you can do without changing the cradle mounts and the knuckle.
I'll post some pics of additional design options in a week or so.
Post by: Fred on April 01, 2013, 05:51:40 pm
I don't quite understand why the helm kit it is such a bad idea.  ???
I am completely awared that it is not the ultimate solution to correct the problem, but isn't it an improvement from the stock attachement with the tie-rod attached from the knuckle to the craddle?
Fred
Post by: aaron88 on April 03, 2013, 12:34:12 pm
There is no doubt that it is an improvement over stock as the bump steer is greatly reduced.  But it's also a high maintenance item.  If you replace the rod ends in that kit with rebuildable ones you should be able to avoid the re-alignment issue.  How many kilometers do you plan on doing per year?  Typical rod ends are only good for about 10 000km.
Post by: aaron88 on April 20, 2013, 04:48:37 pm
Here is another design I'm working with and will most likely build very soon.  Poly universal pivot bushings.
(http://i38.tinypic.com/2djv5e8.jpg)
Post by: Fred on April 20, 2013, 08:45:31 pm
Whats the geometry difference over the other design you have?  :)
Just wondering, would this one be compatible with a stock cradle? Again, I'm not an engineer but it really looks like the bump steer kit.
In any ways, great job as usual! ;)
Fred
Post by: aaron88 on April 21, 2013, 12:33:02 pm
Both designs I'm using have almost the same geometry but different advantages and disadvantages.  For example.  This design can be altered to fit on an existing cradle.  Also the outer polyurethane can be exchanged for spherical bearings for a tighter rear end.  It's also possible to have the spherical bearings interchangeable with the poly.  That way if you have a track day you can just change them out without having to worry about the alignment.
One of the problems with the AMS bump steer is that it's making a correction to a control arm that is already tilted off the camber axis.  That's why the suspension can't move without affecting steer.  That on top of the flex and wear issues already described.
Once I have a working prototype then I'll be able properly identify the real world advantage.  Anything before that is still theoretical.
