Title: it's started Post by: Boy-z on June 10, 2003, 10:42:04 pm Well I got the engine out and it is of to the shop to be rebuilt it came out very good everything looks ok The bracket that holds the rad is a little worst for wear and it is discontinued as is most stuff for the fiero but I am sure I should be able to make something up. besides that I guess it's sit and wait till I get the engine back. O yes had to cutt the cradle bolts off they were seized tighter than a nun's ---- but luckily I could order these.
Title: Re:it's started Post by: Sentinel on June 11, 2003, 08:36:34 pm Karl why you getting the engine rebuilt? Just because or did something happen?
Title: Re:it's started Post by: Boy-z on June 11, 2003, 10:28:27 pm Let me rephrase that I am having the heads done and the valves. I had to replace the head gasket so I thought I may as well have the heads done and valves. If I am that deep into it . Just to spruce them up The thought off doing the head gasket was enough so I;ll do it all at once .
Title: Re:it's started Post by: Sentinel on June 11, 2003, 10:33:41 pm right on, well hope it all goes smoothly for you.
