November 01, 2024, 07:24:36 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: my fiero is going to be back on the road :) « previous next »
Pages: 1 [2] Go Down Print
Author Topic: my fiero is going to be back on the road :)  (Read 4663 times)
lercs
« Reply #15 on: July 23, 2006, 01:49:20 am »
May need a shim under it.
thats what we are thinking, and what is on the agenda for tommorow
and of course the rear seal of the motor is leaking.. just my luck i didnt change it while it was out of the car... should have thought about it then.
lercs
« Reply #16 on: July 27, 2006, 03:23:47 am »
so looks after changing the brake line in the front, one of the brake lines in the back went.. so time to just change them all  Cheesy
Sock Rocker
« Reply #17 on: July 27, 2006, 09:09:27 pm »
AAAHHHH the joys of brake troubles, mind if i hop on that boat my right rear line went on the way home tonight, talk about a fun trip Cheesy
The tiny storm in your teacup
1985 Coupe 2.8
1987 coupe 3.8sc
1985 Coupe dead and mostly gone
1984 coupe donor car
lercs
« Reply #18 on: July 28, 2006, 12:43:03 am »
my brake lines have broke when i was driving as well, it wasnt to bad...  just stayed away from main roads and cars
so after changing all the brake lines except the big long one going from the front to back, and finally starting to bleed them, guess what happened?
you guessed it, the very last non changed brake line went.. so changed the final brake line, and tommorow morning im bleeding the brakes and never ever worrying about them again Smiley
« Reply #19 on: July 28, 2006, 08:25:36 am »
You really like to curse yourself, don't you?   Wink
lercs
« Reply #20 on: July 28, 2006, 09:55:51 am »
lol, ya well its done now, so im happy  Cheesy
lercs
« Reply #21 on: July 29, 2006, 01:29:27 am »
ok after shimming the starter to hell, it doesnt seem to be the starter  Huh
do you think if i uploaded a video of the engine starting that it one of you guys might have some insight in whats happening?
lercs
« Reply #22 on: August 01, 2006, 12:04:27 am »
and it starts
seems to have been the drive plate(flywheel) the nuts had become lose on it somehow
its back in the car now started it up, and it sounds good now
so now to deal with the rust
lercs
« Reply #23 on: August 01, 2006, 10:14:47 pm »
took the fiero for a spin around the block, its not running perfect, but it does drive Cheesy
when i put the car away one headlight worked perfectly and the other only went up
now they both only go up, and you have to put them down manually
could this be the relay?
« Last Edit: August 01, 2006, 10:16:33 pm by lercs » Logged
« Reply #24 on: August 02, 2006, 08:09:17 am »
Assuming that you have the 1st generation headlight system, the most likely culprits are the headlight switch and the isolation relay.
lercs
« Reply #25 on: August 02, 2006, 04:09:15 pm »
alright i have some spare relays i will try them out
lercs
« Reply #26 on: August 04, 2006, 01:38:40 am »
some pics are up
http://www.fierodrivers.com/forum/index.php?topic=2902.0
Pages: 1 [2] Go Up Print
