November 02, 2024, 12:36:09 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Knocking from top end? « previous next »
Author Topic: Knocking from top end?  (Read 1881 times)
tweeder
« on: August 05, 2012, 06:12:37 pm »
I have a 90's 3800 swapped buy a previous owner. The bottom end
was supposedly done a few weeks ago. There is one or two knocks
when it's fired up then as it gets warmer it will become more noticeable.
That and when revved a few thousand rpms, but will go away if letting
off the throttle. I took a stethoscope and it sounds like its coming from
the front left( when standing at the back and looking forward). So I
pulled off the valve cover and all looks fine no broken rocker or spring.
Maybe a lifter?
tweeder
« Reply #1 on: August 30, 2012, 11:48:11 pm »
Pulled the pan and it's a connecting rod bearing.  I will replace it and
hope it lasts another month and a half intill it gets parked and the
3800sc gets swapped in.
« Reply #2 on: August 31, 2012, 02:24:49 am »
Sounds like you have it under control now.  That kind of noise is almost never okay.
