April 18, 2025, 12:07:49 am
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: Wiring Diagrams Anyone? « previous next »
Pages: [1] 2 Go Down Print
Author Topic: Wiring Diagrams Anyone?  (Read 6525 times)
Rob
« on: October 27, 2003, 10:53:04 pm »
Just to let you all know, That I have access to Wiring Diagrams now for basicly any car/engine, so if you need anything let me know.. I dont have a scanner so I would have to send you hard copies(paper)
Later; Rob
« Reply #1 on: November 22, 2003, 05:57:52 pm »
could really use the diagrams for the 97 Grand Prix 3800 series II non supercharged engine and PCM. Thanks.
« Reply #2 on: November 23, 2003, 03:27:09 pm »
I need to know the colours for the fuel tank pump wires.  In particular the colour of the power and ground wires (the other will identify themselves).  The car is an 88 Fiero GT.
I had the whole thing apart when I put in the new pump, but I seem to have lost the paper with the wire designation on it, and I don’t want to have to take it apart again to just for that.
I can’t find the wire colours in the GM manual.
Please, someone help.
« Reply #3 on: November 23, 2003, 05:40:28 pm »
Aaron don't know for sure if 84's are the same but the dissassembled 84 in my garage shows the fuel tank wires as red for pump power pink for sending unit and black for ground. Isn't wiring fun I am in the process of finishing the rewiring of this 84 for a 97 3800N/A swap.
JoeLutz
« Reply #4 on: November 23, 2003, 10:59:50 pm »
Wow this could really be a very usefull resource.   There have been many times when I would have loved to have acces to various wiring diagrams when working on custom projects or doing repair work.
If you would like, you can send me some diagrams and I will scan them and host them on my website so people can just access them through the net.
We could start a list of usefull diagrams people would like to have.  I for one would like to have engine/powertrain diagram for a 96 Chevy truck Vortec 5.7L and a 94 LT1 Camaro or TA.
Thanks,
Joe
a.k.a
« Reply #5 on: November 26, 2003, 04:31:32 pm »
he he
if you can find me these, I will buy you a 24! (or equivalent  Wink )
ok 1978 Cadillac Coupe Deville
Engine harness
Chassis Electrical
Charging system
(either or)
thanx Man!
a.k.a
a.k.a
« Reply #6 on: November 27, 2003, 07:45:16 pm »
also, how bout some diagrams (from the ecm) for a 2.8 out of a 88 gt? (i think its an 88 gt, aaron88?)
Rob
« Reply #7 on: November 30, 2003, 05:13:25 pm »
Wow all of a sudden all these people want wiring diagrams.. must be Winter! haha  okay I will do my best to get all you guys want.. I will try to get most of them tomorrow since I will be in the shop.. Im not sure about that '78 caddy.. I dont know if it goes that far back, but I will sure check for you!
Later Guys; Rob
Rob
« Reply #8 on: November 30, 2003, 05:18:36 pm »
2ML67:  I dont know if you have a scanner, but I live in Belleville on the weekends, and it would be easy for me to get you the diagrams to scan.. Anyways, just an Idea
Later; Rob
a.k.a
« Reply #9 on: December 01, 2003, 06:41:56 pm »
Later Guys; Rob
haha
78 caddie: didn't think so! no worries!
« Reply #10 on: December 02, 2003, 07:51:36 am »
Rob I was already able to get the diagrams for the 97 but yes I do have a scanner so next time in Belleville drop by and I will scan and send out the other diagrams for you. You can laugh at my mess of Fiero's.
I live south of Belleville on county road 2 just north of Wellington. Not far as it only takes me about 15 minutes to get to Loyalist college from where I live.
« Reply #11 on: December 02, 2003, 10:50:25 am »
No need to get me those wire colours, I used an ohm meter to find the right wires.  Field coil 1 ohm (must be the fuel pump), fuel level variable resistor 38 ohm.  So it’s all taken care of.
Marc; it is an 88 GT.
« Last Edit: December 02, 2003, 10:52:23 am by aaron88 » Logged
Rob
« Reply #12 on: December 02, 2003, 11:02:55 am »
okay, 2ML76, id love to see your 3.8sc car! okay.. about that '78 caddy.. sorry can only go back as far as '83 haha wich is still pretty good.. 20 years worth of cars available.
later
a.k.a
« Reply #13 on: December 02, 2003, 02:06:15 pm »
later
78:caddie
np np guy....83 damn that is good!
« Reply #14 on: December 02, 2003, 07:25:41 pm »
Actually at this moment my 3800SC car is outside with as Gary puts it the heart ripped out to allow for detailing over the winter. Outside with it sits patiently a yellow 88 awaiting a 3800SC swap and inside the garage sits a purple 84 in the process of recieving a 97 3800N/A swap. So it is pretty messy here right now so be prepared for the sight of partially stripped Fiero's. Hey my place is getting more and more like Gary's every day.
Pages: [1] 2 Go Up Print
