finally had a chance to work on the car this wknd and last a bit and have made a bit of progress on the quest for unequal length A arm suspension all round. As some may know, the rear McPherson struts are gone (partly to ensure that I keep going with the project....LOL
So a few pix to update on what I have managed and found out and so on. This is all part of upgrading the suspension - altho it won't be for everyone and might not be for me other than on the track - the shocks I am using are 3" of total travel with VERY heavy springs to control ride height adjustments and total compression on corners and bumps.
So first pic is the 3rd generation adapter I had to build to connect the rear knuckle (or upright) to the wheel and the car (shock, frame, 'new' upper A arm, etc). Once I got that figured out the rest wasn't so bad; but the frame reinforcement was VERY fussy and time consuming work; not that it is done yet; as you will see, the shock is not mounted yet but it is almost academic at this point; there are not too many choices to make now; simply make a mount and weld it in place.
So: the 3rd try at a wheel/suspension adapter: (the one on the right; the left is the 2nd gen but I didn't like how it was going to work)
