November 01, 2024, 03:27:36 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Rack it up! « previous next »
Author Topic: Rack it up!  (Read 1725 times)
« on: November 04, 2003, 10:31:43 am »
Were all '84 through '87 steering racks the same, or were there variations in the pinion ratio?
« Last Edit: November 04, 2003, 10:34:12 am by Don Guy » Logged
« Reply #1 on: November 04, 2003, 12:01:18 pm »
AFAIK, there are at least two.  Can't tell you what year or how to id.
One is something like 2.5 turns lock to lock and the other 3 (numbers a guess).  Trial and error may be the only way, I couldn't tell you how many turns it is on my own.
« Reply #2 on: November 05, 2003, 09:26:48 am »
P'raps it's the 84-85 "WS6" package vs. whatever they put in the 86-87?   Huh
I think you're right though--it's probably easiest just to count the number of turns from lock-to-lock.
34FieroGT
This, is my BOOMSTICK!!!
« Reply #3 on: November 05, 2003, 02:46:33 pm »
Gary is right: there are two different racks available.  A 3 turn lock-to-lock, and a 3.5 turn lock-to-lock version.  AFAIK, the 3.0 unit was only found on GTs and the '84 Indy, but I'm not sure on the Indy...  The 3.5 unit is found on all other models.
tyler...
« Reply #4 on: November 05, 2003, 03:05:12 pm »
Good to know--thanks Tyler.
Any idea if there are casting numbers, or another means of identification other than counting the lock-to-lock turns?
BootMachine
« Reply #5 on: November 05, 2003, 04:33:34 pm »
Know what would be really neat...if you had a 3 quarter turn to lock wheel and a massive powersteering pump to handle the gearing.
That way you could keep both hands on the wheel at all times and just cross your arms for the full turn....would be cool for SoloII
A.K.A
« Reply #6 on: November 05, 2003, 05:41:29 pm »
funny you should say it that way[/] the new 5 series BMW has what we call "active steering" that works kinda on that principal... .. . .
