April 10, 2025, 06:00:02 pm
Ottawa Fiero Club Forum  |  Off Topic  |  Other  |  Topic: Power outage....back online now! « previous next »
Author Topic: Power outage....back online now!  (Read 2754 times)
Gizmo
« on: November 15, 2003, 03:21:43 pm »
I swear these things only hit us, well and the ski hill plus some neighbours also.  We were without power for 46 hours, finally came back on a few minutes ago.  The UPS will only run for so long before all hope is lost.....
On my shopping list next time I go to Princess, a big generator.  Thought I saw a surplus on a pallet plus a nice 20hp twin engine that would run it half decent  Grin  Unless someone has a 20hp+ they want to donate to the cause, lmk!
« Reply #1 on: November 17, 2003, 08:45:55 am »
Nick, you're not alone.
I never owned a UPS before I moved in to my current apartment; I bought one out of fear for my hardware a month after I moved in.  Seems like any little bit of excitement from mother nature gives us a least a brown-out.   Roll Eyes
It might be overkill to some, but if I ever finish building a "running" stand for the 'Stang's original motor, I'm sorely tempted to hook a generator up to it's tail!
« Last Edit: November 17, 2003, 08:46:23 am by Don Guy » Logged
« Reply #2 on: December 02, 2003, 10:44:43 am »
Nick, Take some more Car batteries and Wire them  in Parrellel with the UPS! Wink
« Reply #3 on: December 02, 2003, 11:38:54 am »
Is the battery part of the UPS a 12 volt or a 24 volt?  You may need to wire in a couple parallel series circuits.
Gizmo
« Reply #4 on: December 02, 2003, 01:47:16 pm »
You could say I got bored.  Grin  I've already gone that far....I have a bank of 4 marine deep cycles in series and parallel....being nicely floated at 28 volts.  For the times when the power goes, and I happen to be around, I have a 4 hp engine running an alternator, running to an isolator and into each 12 volt bank of batteries.
