April 26, 2025, 07:35:46 am
Ottawa Fiero Club Forum  |  Off Topic  |  Other  |  Topic: Replacing main bearing caps... « previous next »
Author Topic: Replacing main bearing caps...  (Read 2757 times)
« on: January 14, 2004, 09:45:26 am »
...on a VW.  Eeeew!
But it has to be done.   Undecided
Having never done it before, I'm looking for someone "in the know."  Is it a simple matter of purchasing the new caps & installing them, or should I dig up some plastigauge & check the clearances first in case the bearing surfaces on the crank have worn significantly?
« Reply #1 on: January 14, 2004, 09:57:01 am »
if it's knocking, it too late. You need to get the crank checked for scores ect.
if not.. you need to plecsy? gauge the bearings and get the appropriate replacement.
« Reply #2 on: January 14, 2004, 10:38:06 am »
Nope, not knocking thank goodness.
All of the symptoms it currently has, plus a track record for that particular engine, are pointing a big, fat finger at mains that are worn just enough to cause problems in the oil pressure department, but not enough to produce any noticable knocking.
So I do need to get the new caps properly sized, eh?  Thanks Eric!
Now I have an excuse to buy a new tool...  mmmmm   Grin
