April 26, 2025, 03:35:33 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: 3.4L engine donor, other than F body? « previous next »
Author Topic: 3.4L engine donor, other than F body?  (Read 2573 times)
« on: January 15, 2004, 08:47:11 am »
Whe cars carry the 3.4L engine that discuises itself as a 2.8L when in a Fiero other than the F body 3.4L ?
« Reply #1 on: January 15, 2004, 10:39:10 am »
Huh?
« Reply #2 on: January 15, 2004, 10:40:35 am »
Huh?
ok.. it did sound confusing from the way i wrote it.. What cars have the same 3.4L as the Camaro. Smiley
cheers!
« Reply #3 on: January 15, 2004, 12:20:58 pm »
Firebirdie!!!
LOL, you asked for that, Eric.  I think that is what you want.  GM sells the 3.4 over the counter as a replacement for the S-10 series (2.Cool, but they only come as a 2.8 or 4.3 stock. The 3.4 has a stronger block but uses the same heads as our 2.8.
The later fwd engines are all 3400 with aluminum heads (AFAIK), a different animal.
