well, from what I have been told / experienced
Bushings are definately an issue, and if you are upgrading components anyways this will be a good time to swap the rubber ones
I prefer the poly although it will give you a harder ride
The fiero store sells a full line of poly / oem replacement bushings
Rubber will last longer, but it can cost more depending where you go...
...Remember the cradle bushings too...
As for shocks, every1 has thier preference, but you can't beat KONI ( if you can afford them )
If you are going to be off the track, koni's probably will be too extreme...kyb is a good name too but they also can be pricey
For my setup, I am going with oem replacement Munroes for my shocks and Eibach for my springs
Eibach has proven themseves to me time after time and are the best bang for the buck
They make the car handle much better but don't jeapordize ride quality that much
For ball joints, just get some lifetime jobbies, ( I don't think there are many hi-po ball joints on the market
As for swaybars, I can only pass on some info that was given to me ,( never actually checked it out )
but if you swap your front one to a 1"
and your rear to 7 / 8 " that should tighten up the bottom end big time
Especially in the skid-pad
If you want to grab some prices, hit me up with a pm or an email...I can probably do 40 bucks a shock and 350-450 for the drop springs and can snag some lifetime ball joints too
The bushings, as mentioned before, can be found @ the fiero store
http://www.fierostore.com )
hth
a.k.a
aka_fiero@hotmail.com
