April 04, 2025, 04:11:58 pm
Ottawa Fiero Club Forum  |  Off Topic  |  Jokes  |  Topic: Electrical Theory « previous next »
Author Topic: Electrical Theory  (Read 2688 times)
« on: February 16, 2004, 01:21:34 pm »
Light bulbs do not emit light.  Really.
In reality, they suck up the dark.
Ever notice how black a burned-out light bulb looks?  That means it's full of dark and needs to be replaced with an empty one.  Further, when a bulb is nearly "full", it may flicker.  If you tap it, and knock some of the dark out, it has room for more and thus will "light up" again!
a.k.a
« Reply #1 on: February 20, 2004, 01:36:58 pm »
good friday afternoon chuckle  Cheesy
« Reply #2 on: February 29, 2004, 01:51:47 am »
As far as detailed info. goes your not really far off  Shocked
Hot or cold, heat is fiction. So therefor, removing the cold should really be adding warm or hot air or atoms!  Grin
« Reply #3 on: February 29, 2004, 01:53:16 am »
But whats happens when you drop and brake a bulb?
