oh ya! forgot about that.
you need the shifter of a 5spd fiero. (any 5spd. )
you need the shift and select cables.. or do you?? is the 4spd compatible to the 5 spd issuzu? I know the getrag needs special cables, but issuzu ? Oh yes! the connectors are different!
Call som recycling places near by.. I know there is one in Gatineau ro near there that has a few Fieros. (called the guy a while back)
You will also need the %$@# issuzu brackets.
had a fun time finding those without a tranny bolted to it.
if you have the cash to forward, do like me.
ordered a clutch kit for a 2.5L fiero 5spd and a clutch kit for a 2.8L getrag (87 fiero 5spd), (same price) take the issuzu bearing from the 2.5 kit and take the clutch and pressure plate from the 2.8L kit. then return the other kit to Canadian tire.
Now you have the bigger clutch that fits nice in the issuzu. Not sure the 2.5L will make any use of it, but hey, better for same price.
will reduce clutch heat.
What else.. axles are the same.. but get axle seal! only like $20.00 but worth it!
humm... 5spd sticker on your shift console.. some backup light wiering (easy to do)... what else.. thinking... Speed sensor is the same, use the gear on the sendor of the issuzu.. oh,. and a 4.9L caddy engine.
cheers!
