April 18, 2025, 01:37:21 am
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: memcal infor for 3800sc « previous next »
Author Topic: memcal infor for 3800sc  (Read 3525 times)
« on: March 02, 2004, 11:41:57 am »
Just a database of info i am cutting and pasting in here. i will sort it all later. Smiley
« Reply #1 on: March 02, 2004, 11:47:40 am »
Chip Programming for engine swaps or performance modding
Most engine conversions require making changes to the Engine Control Module (ECM) in order to make the swap perform perfectly, or even work at all. The changes may be as minor as turning off one or two error codes or disabling anti-theft systems, or could be major changes such as completely re-tuning the fuel delivery and spark timing for a highly modified engine. It's also not uncommon to take an ECM that was designed for a particular engine and use it to run a different engine. I won't get into how to edit any specific ECM, there are other sources for that information. I will try to give you a basic understanding of how it is done.
Most GM ECMs used until 1995 have an Erasable Programmable Read Only Memory (EPROM) that stores data about the particular engine it controls. Some EPROMs also contain information specific to the transmission and the car. The EPROM is often referred to as the "chip". The chip is sometimes located in a removable carrier called a MemCal or Calpack. To edit the chip, you will need a few things. You'll need a PC or laptop computer, since you are reading this I'll assume you already have one. You will need an EPROM programmer or device programmer that is compatible with the EPROM in your ECM. You will need an EPROM eraser, most stock GM EPROMs are erasable and reusable. You may also want to have a few 'spare' chips to work with. And lastly, you will need editing software that supports the ECM you are using. It takes some time to learn how to use these tools, and it takes some money to get started. Unless you can make use of it on several projects, you'd be better off just finding someone who can do it for you.
I use the following tools for all of my editing.
Needham's EMP-10 device programmer. It is fairly inexpensive and covers all of the EPROMs used in GM ECMs. Visit http://www.needhams.com/ for more information or to order one.
Datarase II EPROM eraser from Walling Co.. Erases four chips at a time. Most inexpensive eraser I could find. I bought mine from http://www.digikey.com/
GMEpro editing software from Terry Kelley. This software has coverage for lots of different vehicles. Excellent tech support. A shareware version of GME for the 85-88 V6 Fiero can be downloaded by clicking here. Contact Terry at terryk@foothill.net to purchase the fully functional editor and .epe files for other ECMs.
« Reply #2 on: March 02, 2004, 11:49:46 am »
Fiero C203 & C500
This is a list of all the connections that are needed to tie into the Fiero electrical system when doing an engine conversion. This list is to aide in the wiring process. All circuits should be verified before any connections are made. To the best of my knowledge, all of the info below is correct.
The C203 connector is clear plastic and located under the center console. The C500 connector is next to the battery, half of it is for the tail light harness, the other half for the engine. Descriptions of each one follows:
Fiero C203 connector
Pos. Wire color Circuit Description
A Tan/Black Upshift lamp Grounding this wire will make the upshift indicator come on.
B Orange Fuel Pump Positive feed for the fuel pump relay. Hot at all times fused 10A
C Brown/White SES lamp Grounding this wire will make the "Service Engine Soon" indicator come on
D Lt Blue A/C on Positive feed for the A/C compressor control relay coil. Hot when A/C is on.
E Tan Oil gage Connect to oil pressure sender, 90 ohms at max pressure
F Pink/Black ECM Ign. Positive feed for ECM. Hot in run, bulb test, or start. fused 10A.
G Yellow VSS high VSS input to speedometer. Connect to magnetic VSS or converted 4000 PPM signal from ECM. Note 3
H Brown VSS feed for ECM Feeds buffered VSS signal to ECM when a magnetic VSS is connected to speedometer. Note 3
J Pink TBI INJ1 Positive feed for injector. Hot in run, bulb test, or start. fused 5A
K Pink TBI INJ2 Positive feed for injector. Hot in run, bulb test, or start. fused 5A
L Tan/White Fuel pump Positive side of fuel pump, gets connected to the COM terminal of the fuel pump relay.
M Black VSSB ground Connect to ground
N Black A/C Power Positive feed for A/C compressor control relay contacts. Fused 25A
P Purple TCC Brake switch TCC brake. Hot in run, bulb test, or start only when brake pedal is NOT depressed.
R Purple VSS low VSS input to speedometer. Connect to magnetic VSS or to ground if using optical VSS and converter. Note 3
Notes
1. F is the switched power feed for the ECM, all switched 12 volt inputs on the ECM can be connected to this terminal. The constant 12 volt supply for the ECM comes from the rust colored fusible link with a single weatherpack disconnect at the terminal block near the battery.
2.  J, & K are the positive feeds for the fuel injectors, One for each injector on TBI systems or one for each bank on PFI systems.
3. The Fiero speedometer system works differently than most other GM vehicles. Click HERE for more info.
Fiero C500 connector
I've found that the C500 connections vary considerably depending on year.
A2 Black Ground Ground
A4 Yellow Start Hot in start, connect to gear selector switch. Automatic only
B3  Brown Charge Charge indicator light. Connect to alternator brown wire.
C1 Dark Blue Reverse Reverse light switch power feed. Connect to gear selector switch(auto.) or reverse switch(man.) Fused 10A. Note 1
C2  DkGreen/White(V6)
Tan(L4)
 Temp gage Connect to temp sender, 1365ohm@100deg.,55ohm@260deg.
C3 White Tach Connect to coil or ign module.
D1 Dk Green/white Fan switch Connect to grounding fan switch or ECM fan output
D2 Lt Green/Black Fan switch Same as above(with optional two speed fan only)
D3 Dark Green Temp lamp Connect to grounding temp switch or ECM temp output.
E1 Lt Green Reverse Connect to gear selector switch(auto.) or reverse switch(man.) along with C1. Note 1
E2 Purple Start Hot in start, connect to starter. Manual only
E3 Pink Ignition Hot in run, bulb test, or start. Power feed for ignition coil
Cars equipped with four speed manual transaxle use a shifter mounted reverse switch. Cars with five speed use a transaxle mounted switch. '85 and newer cars are wired for both switches.
There is a stud terminal directly under the C500 for making all +12 volt constant connections.
The Fiero uses a separate module for cruise control. It is located behind the carpet on the drivers side inner kick panel. If you wish to use the new donor ECM to control the cruise control (recommended), you will need to extend the wires from the original module to the new ECM.
« Reply #3 on: March 03, 2004, 07:21:08 am »
memcal programmer adaptor
« Reply #4 on: March 03, 2004, 07:21:36 am »
another view
« Reply #5 on: March 03, 2004, 07:22:52 am »
you just need to ba able to do a 27512 EPROM
28 pin
