April 13, 2025, 11:56:40 am
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: EGR TUBE « previous next »
Author Topic: EGR TUBE  (Read 2957 times)
lsixtyseven
« on: March 31, 2004, 01:16:15 pm »
My egr tube is broken right off of the flange underneath the plenum, has anyone repaired this tube, or know of a way to repair it.
« Reply #1 on: March 31, 2004, 02:25:52 pm »
2.8 ?
I believe it can be brazed.  Or a Firebird one will fit, if the holes are elongated a bit, it's supposed to be stronger.
I have a used Fiero one here if you need it.
lsixtyseven
« Reply #2 on: March 31, 2004, 03:40:35 pm »
I'm going to try brazing it, and if that doesn't work and nobody else has any ideas then I will take your used tube.
I was wondering if a copper pipe would work, any thoughts?
« Reply #3 on: March 31, 2004, 03:53:29 pm »
just to suggest that you weld it ("braze with steel rod") rather than bronze rod....
it will be MUCH stronger and should stand up to temp and vibration a lot longer. Once you start using bronze you will be stuck with that as you prob know.
just 2 cents....
lsixtyseven
« Reply #4 on: March 31, 2004, 05:48:45 pm »
Trying to weld the flange to the tube was burning holes in the tube, Cry it is very thin. I was fed up with that so went to the bronze rods. The bronze did the job but then i had to braze the new holes i made in the tube.
Hope it works.
