April 26, 2025, 08:32:09 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: how to tell the difference between trans types? « previous next »
Author Topic: how to tell the difference between trans types?  (Read 1745 times)
« on: May 23, 2004, 10:29:52 am »
just as a memory jog to me; what is the key item to watch for when looking at 5 spd transmissions; one has an aluminum end plate and the other is steel?  I think the Getrag is steel?  Any other things that are obvious?
And I presume this end plate is at the opposite end from the clutch or no?
Hope to do a 'wreckers' run this wk coming so want to know what I am looking for.
tia, all!!
« Reply #1 on: May 23, 2004, 12:38:56 pm »
Best way is by shifter mechanism on tranny Getrag one is like 4 speed tranny all built in sticking straight up. Isuzu one is a bolted on cylinder type coming up top of tranny. Once you actually see what I mean you can't miss it after that. Dan
