April 19, 2025, 04:51:54 am
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: rear upper (yes) control arms « previous next »
Author Topic: rear upper (yes) control arms  (Read 2135 times)
« on: May 23, 2004, 12:03:50 pm »
a little update;
mocked things up to check camber gain thru my suspension travel and it looks OK for a first time around:
I have NOT set it at exactly zero camber for ride height; I just eyeballed it and I know that I have a bit of shimming to do but wanted to see if I was close and I think I am.
first pic is with the control arms set at ride height.  (By the way, I will have a 'track' suspension setting that will be 1.5" lower but that is next time around)
2nd pic is of max compression; nice little bit of negative camber gain that should nicely compensate for body roll and tire distortion on corners...... Grin
Bottom goes the same way but I am not as concerned about the camber change; it is the 'outside' corner that I am more concerned about of course.
Just thought I would post an update.
« Reply #1 on: May 24, 2004, 06:16:25 pm »
very cool  Cool really giving me the itch to get at my suspension (checks bank account balance) DOH!!!!  come on June paychecks, daddy needs needs new parts.....
« Last Edit: May 24, 2004, 06:18:52 pm by Sentinel » Logged
« Reply #2 on: May 24, 2004, 08:22:52 pm »
well it is a bit encouraging, so far.  Next is to check for toe in or toe out on wheel travel up and down.
THAT is the biggie - and the reason for doing it!  And I should get better (less) camber change when set at the 'race' setting so that is another switch I have to make and check too.
Slowly it is coming.  But if this works I get to take the cut off wheel to the other side and presto! No more McPherson struts!
