January 17, 2025, 02:31:26 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: car bogs down when accelerating « previous next »
Author Topic: car bogs down when accelerating  (Read 1321 times)
JP_86_2M4
« on: June 03, 2004, 08:45:05 pm »
good evening everyone,
I've been having this problem for a long time on my 2M4 now and cant figure it out.  I have sent an email to the fiero list and some people say its the gas filter, or the coil, ignition module, and a vacuum leak.  I have changed the gas filter, checked the coil with a multimeter, and I cant hear any vacuum leak.  However today someone told me that it was the injector or the thing that is inside the air filter that is defective.  So I desided to take the cover off the thing seeing as it was pretty dirty and the connectors were dirty too so I cleaned it with a rag.  I also had the new gas filter so I replaced that too and then cleaned the engine so that no gas was left on it.  After everything was dry, I started it and now the bogging down problem is there all the time!!  The problem used to occur occationally, but now it does it all the time.  If you keep the gas steady it will eventually take the gas, but takes like 1-2sec and then it doesnt it once in a while.  The problem seems to be around that area but seeing as I'm not mechanicly inclined, I am leaving you guys answer that one.  hehe
Rebel
« Reply #1 on: June 04, 2004, 10:04:16 am »
I have had similar problem with my 2.5
I found running a fuel cleaner  change the old coil the seem to leak with age
You also should check timings will give you delay
I also found distributor needs service it leaks at low output
making engine misfire
Gas filter in the tank ca also give low pressure cause slow responded
If you  have any ? Email I see what I can do to help you
Rebel hope this helps you
Fiero_power
« Reply #2 on: June 04, 2004, 03:05:27 pm »
I had that about a year ago with my 2.5.  Make sure your distributor is good.  I had a hair-line crack that I couldn't see until I took it off and looked at it up close.
JP_86_2M4
« Reply #3 on: June 05, 2004, 09:40:09 am »
I finally got it fixed!!
it was only the rotor and distributor cap that was defective.  It was bogging down after I washed it because water/condensation was building up inside the cap and the rotor was never changed since I got the car 5 yrs ago...hehe
runs great now!
 Grin
« Reply #4 on: June 05, 2004, 05:02:18 pm »
that's good news, gotta love when it's a easy/cheap fix
