January 19, 2025, 03:30:24 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Inquiry « previous next »
Pages: 1 [2] Go Down Print
Author Topic: Inquiry  (Read 4276 times)
« Reply #15 on: June 13, 2004, 10:23:34 pm »
I have tried posting pictures but I am on too slow of dial up for the sites liking. I will be removing motor, tranny, PCM, fuel tank, tires and rims. Everything else goes with the car, I have stock wheels to put back on her. Engine cradle is good will be left with the mounts still on it as well as the proper axle shafts. Will also supply complete notes on the wiring and mounting of the drivetrain. Car already has battery mounted under pass head light as well as 87/88 headlight assy's. Will be looking for around $1,500 for her.
heheheha
« Reply #16 on: June 13, 2004, 11:34:21 pm »
Is the PCM the stock Fiero one? What color is the car? Is it set up for a stick or automatic trans? Fastback model? And where are you located?
When you are ready to sell it, I might be ready to stop by and look at it and give you money... Smiley
« Reply #17 on: June 14, 2004, 08:21:35 am »
PCM is a stock 1998 Grand Prix GTP one, car is set up for the 4T65E 4 speed auto tranny and is a red notch back. I am located just south of Belleville and she can be ready any time all I have to do is pull drive train. Dan
Rob
« Reply #18 on: June 14, 2004, 10:07:17 am »
About how much does a the 3.8 sc engine go for around here?
« Reply #19 on: June 14, 2004, 12:05:47 pm »
Can usually get a set up consisting of engine, tranny, wiring harness, starter, PCM and matching pass key for around $3,000 plus taxes. Thats at Hotch's south of Belleville they usually have at least one on stock. Right now they have one out of a 99 Park Avenue Ultra with 87,000 km on it. Dan
Pages: 1 [2] Go Up Print
