January 11, 2025, 01:16:03 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: stripping 84 « previous next »
Author Topic: stripping 84  (Read 2058 times)
« on: July 24, 2004, 01:38:13 pm »
Stripping one of my 84 parts cars if any one needs any thing let me know before the shell is hauled away. It was a 4 speed car with the 410 tranny. Dan
poupas
« Reply #1 on: July 25, 2004, 01:34:11 pm »
Hey Dan. How are you doing? Dont know what parts you have left but here is what I could use: ashtray doors with springs, overflow coolant resevoir, passenger side mirror(half my mirror has a reddish discolouration on it, I just need the reflective part), battery tray(mine does not exist). Let me know if you have any of the above.
                                        Thanks
                                                Andrew
poupas
« Reply #2 on: July 25, 2004, 01:38:24 pm »
Another question. I am wondering about being able to put a front fiero sway bar on the rear. I have heard you can do it. If you had one on your '84 that you are parting out, what else would I need to put it on the rear of my '86. I dont know if you know anything about this but I thought I would try. If it is quite simple, I would probably take the sway bar as well.
                                               Andrew
« Reply #3 on: July 25, 2004, 02:42:27 pm »
Andrew, Ideally you should have a bigger bar on the front than on the back.  With that in mind, yes you can easily mount a front bar on the rear cradle .  I'm given to understand that others fit as well, Astro van, Bonneville? etc.
Energy Suspension makes a bushing set  in poly if desired, as well as different end link sets.  The number here is one I have but not used.  I think there is a clearance problem and you can only fit in one grommet on one side.
sway bar bushing set 23mm     9.5127G
end link set     9.8117G
I got them through young's speed shop, but you can probably order them anywhere.
If Dan has no ashtray lids, I may be able to help.
« Reply #4 on: July 25, 2004, 08:40:32 pm »
Will check and get back to you but I think I have all the stuff except I believe the 86 up used a different coolant jug. Will remove the sway bar for you as well. Dan
« Reply #5 on: July 26, 2004, 08:37:31 am »
I think Dan still has that near new one that came off of my '88. It should fit.
BTW. I will be going to my moms and will stop by for coffee/tea on Friday (if you are around)
« Last Edit: July 26, 2004, 08:39:16 am by GoFast85 » Logged
mr.tourismo
« Reply #6 on: August 15, 2004, 09:55:03 pm »
i have a link to someone that did the rear swaybar conversion and more mods:  http://www.mindspring.com/~martinwhite/fiero/swaybar.html
i also was wondering if i should do that too. plus the sliding might help with some drifting competion Cool ... while staying under the speedlimit  Roll Eyes
quote from the site
OH MY HECK, it makes a hugh difference. The car doesn't push at all in a corner. I need to drive it some more and run a couple autocrosses to be sure. I LOVE IT. It did introduce some small amount of oversteer. Going aroung a corner under power just corners harder, no push.
and he says it took him 2 hours plus the trip to the hardware store.
Alex
« Last Edit: August 15, 2004, 10:01:03 pm by mr.tourismo » Logged
« Reply #7 on: August 16, 2004, 12:12:50 pm »
I put mine on the 85 and it worked well. True a big one might have been better, but it is still a VAST improvement over none at all.
