April 26, 2025, 12:45:26 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: what to do.... « previous next »
Author Topic: what to do....  (Read 2100 times)
« on: July 31, 2004, 03:58:30 pm »
I bought a motor to do a swap about 9 months ago and I am now getting close to do the swap. Its been setting on the engine stand since just as it was pulled out of the Cadillac STS.
I am already planning on changing the oil, oil filter, plugs and wires. I am going to have the fuel injectors cleaned out of the engine, "somewhere that has a bench mechine". Is there anything else that can be or should be done that I can't think about right now?
« Reply #1 on: August 03, 2004, 09:42:31 am »
A simple thing, but valve cover gaskets. They are only about $30 but are easy to install when the engine is out but a @!#$% to change when it is tight in the engine bay.
« Reply #2 on: August 04, 2004, 01:19:51 am »
The what was front was removed and replaced but I wouldn't say easy, that cam pully was a bit** to remove!
