April 26, 2025, 08:12:36 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: KNOCK KNOCK.. Why me.... « previous next »
Author Topic: KNOCK KNOCK.. Why me....  (Read 2522 times)
Rob
« on: August 02, 2004, 09:12:41 am »
okay, I must have a curse or something Huh ... cause this is the second fiero that within a few days of having it on the road I get to deal with a blown engine.. this cars only got 131k on it!  Im so incredibley depressed right now.. Ive got no money for a new engine, it is supposed to be safetied tomorrow.. anyone know if since its still driveable and doesnt knock under 2k rpm will they still saftey it for me so I can get ownership switched around?
Rob Sad
« Reply #1 on: August 02, 2004, 09:56:48 am »
  The safety check has nothing to do with the engine at all so you will be able to get that done. Can you give us a few more symptoms? You may find sombody here has an extra engine tucked away. Good luck, Kevin.
tach_abrader
« Reply #2 on: August 02, 2004, 01:16:03 pm »
D'oh!  Sorry to hear that Rob.  If you want you can have all my spare 2.8 parts... I've got a complete partially-disassembled motor if you want.
Brad
« Reply #3 on: August 02, 2004, 02:47:01 pm »
Have seen a few engines over the years that were knocking because of a cracked fly wheel. Would check that before tearing any thing apart. Dan
Rob
« Reply #4 on: August 02, 2004, 05:17:03 pm »
What about a flexplate... Im betting a rod bearing, since it is fine at idel but bad once the RPM' go up.. anyways, it goes into the shop tomorrow.. So we shall see!
« Reply #5 on: August 03, 2004, 09:40:16 am »
I have a spare 2.8 in the shed. PM me for details.
