April 26, 2025, 06:57:47 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Frt Lwr Ball Joint « previous next »
Author Topic: Frt Lwr Ball Joint  (Read 1775 times)
Rob
« on: August 05, 2004, 10:26:47 pm »
the book says this must be removed as a hole and replaced with the control arm I think... is there another way of pulling this out??
Thanks; Rob
« Reply #1 on: August 06, 2004, 09:52:42 am »
Your book is mostly correct, with respect to the average backyard mechanic.
The front lower ball joints are pressed in to the control arm, and sometimes tack-welded in as an extra safety measure.  If you don't have access to the appropriate press, doing the job properly will be damn-near impossible.
Assuming that you're comfortable doing it, purchase a replacment ball joint at your favorite parts store, remove the control arm, then take both in to a shop and ask them to replace the ball joint for you.  When I had one replaced earlier this year, it wasn't more than $20 to have a local garage swap the ball joints after I removed the control arm.
Rob
« Reply #2 on: August 06, 2004, 05:18:28 pm »
hmmm sounds like I will leave it for my shop to do then...
Thanks, Rob
