September 21, 2024, 06:52:18 am
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: Fiero 88 dimensions « previous next »
Author Topic: Fiero 88 dimensions  (Read 1720 times)
egirard
« on: August 13, 2004, 09:34:43 am »
Hi,
I try to find the diagram of horizontal and vertical dimensions for Fiero 88.  These dimensions are found in the GM service manual.
Could somebody do a scan and send me a copy?  Cheesy
Thanks Eric
« Reply #1 on: August 13, 2004, 11:18:43 am »
I have a coupe and would also be interested in the "official spec. I thought that you were running a Fiero GT v6 86
egirard
« Reply #2 on: August 13, 2004, 02:24:28 pm »
To be honest, I have 3 Fiero (85 v6 SE, 86 GT and 88 GT).
The 88 Fiero was given to me by a friend.  The problem, is the front left-hand side was damaged.  Cry
Before making a decision, I want to check if the frame were not damaged.
I have already the specifications for my 86, but the suspension of the 88 is different, I know that the back is a little different.
If somebody gives me the specifications, I would forward you a copy. Grin
cheers,
« Reply #3 on: August 16, 2004, 09:15:56 pm »
I scaned this to pdf. but there is an attachment limitation so I'll have to email this.  If you want this; PM me your emil address.
egirard
« Reply #4 on: August 17, 2004, 09:31:30 am »
Please, please send me to egirard@fieromontreal.com  Grin
Cheers,
« Reply #5 on: August 17, 2004, 12:16:41 pm »
Thanks aaron. I received it.
egirard
« Reply #6 on: August 18, 2004, 07:54:02 am »
Hi Aaron,
I received it. Smiley
Many thanks,
