April 17, 2025, 11:05:58 pm
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: 84 vs. 85+ manual shifter « previous next »
Author Topic: 84 vs. 85+ manual shifter  (Read 2559 times)
« on: August 18, 2004, 07:01:07 pm »
Brian...  here's a photo of the two side-by-side.  The one I picked up from Alex is the shorter one.
I measured the difference, but forgot to write it down.   Embarrassed  It's an inch plus or minus a bit.
« Reply #1 on: August 19, 2004, 09:43:03 am »
So the bend is the same, just the upper lenght. The one that I put in my 85  is straight wigh no bend.
« Reply #2 on: August 19, 2004, 10:32:18 am »
Mine has been trimmed at the yellow line and the circled bit removed.  The stub was rewelded onto the shifter.
« Reply #3 on: August 20, 2004, 08:45:49 am »
Was it an 84 shifter that you shortened, or one of the longer ones?
The height of the 84 definitely is more comfortable for me than the 85+, but given that it's so easy to do I think I'm going to cut the "s" out of one of the extra 85+ shifters we have and see if the reduced height & and different reach is more comfortable yet.
« Reply #4 on: August 20, 2004, 11:59:22 am »
Mine was an 84 so the stub is very short.
I find the shaft really fat. If doing it again I would use a lever from a different car with a smaller diameter.  Bent and welded to personal feel.  Make it a lot easier to fit a nice aftermarket shifter knob.
