April 13, 2025, 10:31:42 pm
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: 70 series tires « previous next »
Author Topic: 70 series tires  (Read 3606 times)
fiero1
dark-rider
« on: September 17, 2002, 01:31:38 pm »
As i am planning for next summer im thinking of getting rid of the wheels @ tires @ replacing them by normal 14" rims with full wheel cover i saw one @ i likes the way it looked but i would like to go 70 series tires anyone out their have experienced 70 series tires on Fieros?Huh
« Reply #1 on: September 18, 2002, 08:57:00 am »
  I have the original size 70 series on mine (195-70-14) I find they ride nice.  You can go larger up to 205 on the front and 215 on the back if you want to play with that. What size do you have on yours now?
fiero1
dark-rider
« Reply #2 on: September 18, 2002, 10:51:55 pm »
 ;DHi!well at the present time i have 205-60 but i dont want to go to a larger well i want to keep the 14 inchers...i want to bring the car lower but i dont want to modify the suspension so as i will need new tires next summer i thought getting a 70 series tire but not sure which one will bring the car down lower Undecided
« Reply #3 on: September 19, 2002, 06:47:41 am »
The 60 or 70 refers to the sidewall.  A 70 series tire will be taller than an equivalent 60 series.  Most guys try to keep the overall tire size the same so as not to ruin instrument readings.  Therefore going to a 17  inch rim usually means going to a 40 series tire. (more rim less tire).
I don't think from stock 14's you'll get any significant lowering from tire alone.
Options are pretty much suspension changes.
cut springs
lowered springs
coilovers
dropped spindles/coilovers
