April 26, 2025, 01:28:07 pm
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Help ID a pigtail on an 86 Duke « previous next »
Author Topic: Help ID a pigtail on an 86 Duke  (Read 2455 times)
« on: October 10, 2004, 08:35:31 am »
The red connector in the pics to follow...
It's located in the head, on the side facing the firewall, near what I believe to be the ECM coolant temperature sensor.  Nothing within reach without a plug which looks like it should have one.   Huh
« Reply #1 on: October 10, 2004, 09:32:04 am »
I'm not sure, but just to clarify; is that a dark green and a light green or is it something else?  the light coloured wire is a bit hard to tell.
My factory manual is for an 85 so I don't want to assume it is the same for your 86.
« Reply #2 on: October 11, 2004, 07:50:34 am »
Dark green with a white stripe, and light green with a black stripe, and I mistakenly said that it was next to the CTS when I should have said "fan switch."  It also shares the same loom as the connector for the fan switch.
Someone on PFF thought that it might be the connector for the short-lived two-speed fan systems which the 84's with A/C had, and Haynes seems to confirm that.  Wired for both systems I guess, which I find curious given that it's an 86 yet only the 84's had the two-speed system, and a vastly wiring harness.   Undecided
PBJ
« Reply #3 on: October 11, 2004, 07:54:55 am »
I believe that is the connector for the cooling fan sensor. Although I am more familiar with the V6.
Pete
