April 07, 2025, 03:32:18 am
Ottawa Fiero Club Forum  |  Off Topic  |  Other  |  Topic: Data Recovery Service « previous next »
Author Topic: Data Recovery Service  (Read 2422 times)
« on: December 24, 2004, 07:57:58 am »
Do any of our resident computer nuts know of a local or relatively-local data recovery specialist?
...as in the type of place you take a dead hard drive to, and they try to extract what's on it?
  Undecided
« Reply #1 on: December 24, 2004, 01:38:37 pm »
Tunstall DAta REcovery on .....colonnade rd; east end, at corner of Prince of Wales; in the little plaza there.
they are VERY good; I have used them and they pulled pretty much everything off a 'shot' drive.
They can work on a pretty scary variety of problem drives.  It is not really cheap but if you need the info you are a bit limited in what you can do.
g
« Reply #2 on: December 31, 2004, 11:38:33 am »
Thanks Graeme!!!
34FieroGT
This, is my BOOMSTICK!!!
« Reply #3 on: January 01, 2005, 11:39:27 am »
Don,
   Unless there is physical damage to the disk platters/heads, you may be able to retrieve the data yourself.  I'm not sure how computer savvy you are, but I have been able to resurrect a few hardrives at work using this method.  Tunstell & Tunstell will perform the exact same procedure and charge you about $2000 to do so!
   As I said, if there's no physical damage, you will need to find an identical hardrive (same model number) to your failed one.  Remove the circuit board on the bottom of the hardrives and swap them.  They're typically held together with a few small torx screws.  The circuit board may have become slightly attached to the hardrive case, but some gentle prying should seperate them.  Reinstall the 'repaired' hardrive and copy your data off.
   If the HD has been physically damaged, Tunstell may be your only hope.  I hope that I've been clear enough here to help.  If not, let me know and I'll try to clarify any questions.
« Last Edit: January 01, 2005, 11:58:31 am by 34FieroGT » Logged
tyler...
« Reply #4 on: January 01, 2005, 12:06:47 pm »
Thanks Tyler.  Smiley
I've already tried switching the drive's logic card with that from a known working (identical) drive... no luck.
But...   Undecided  With it hooked up to a system with a more recent host adapter, and keeping it "on ice" (freezer gel packs), it appears to be a bit more interested in running than it was previously.  Hopefully I can continue to coax it along for at least as long as it takes to copy everything to the new drive.   Wink
« Reply #5 on: January 01, 2005, 01:22:45 pm »
hi Don
just for people who are looking at this, I don't know where Tylers $2K came from; maybe from his personal or corporate experience, but my bill was in the $500 range.  I dont think I would have bothered if it was any more.
just for the info in case anyone is interested.
g
