April 17, 2025, 08:08:40 pm
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: Supercharged 3.4 DOHC « previous next »
Author Topic: Supercharged 3.4 DOHC  (Read 3047 times)
Meckanic
« on: February 01, 2005, 03:42:24 pm »
Hi, I am in the middle of a 3.4 DOHC mod (and it's damn cold out there in my garage). I've managed to get the ECM from a 93 GTP standard tranny (and it's modifed for pressure in the hole), I have a pair of 95 GTP 3.4 DOHC's, modified 98 Grand Prix MAF (supercharger flavour), Corvette LS1 (80mm) throttle body, modified cams, 8:1 psitons and of course the M90 Eaton Supercharger (80mm) from a 98 Grand Prix that we modified to produce 22psi plus. Finally, I designed the plenum with 6 additional injectors and specialized waste gate controls. I started off originally with a 2.8 and modified that to give 227hp, but you know it just isn't enough. The 3.4 is being mated to the existing 5 speed Getrag which has new hardened gears and a kevlar blanket (as well as a kevlar firewall blanket, ballistic ejection can be a problem eh!). Has anyone ever attempted this kind of a conversion.. er insanity? If so let me know. It isn't anything like dropping in a 3.8 supercharged because of all the mods that have to take place. Also, if anyone else wants to try this, let me know as well. I know 3.4's can be a problem with the belts and the setting up little things like cams...lol, but personally, I would rather throw a belt than take a pushrod through the back of my head.
« Reply #1 on: February 01, 2005, 03:55:46 pm »
well it sounds very ambitious and complicated but no doubt you have looked into everything before deciding to go the 3.4 route.
A couple of 3.4-specific questions for you:
where did you get your cams modified and what specs did you decide on?  Did you pick the specs or did some shop and if so, who?  As far as I can tell nobody has actually GOT modified 3.4 cams yet (PFF or 60*6 etc) so this is a first!!
the other item is what are you doing about con rods in particular (and maybe a crank, too)?
The bottom end of the 3.4 is somewhat known (according to local wreckers, anyway) for opening 'side doors'.  I don't know if it is the rods or the oiling system (pretty convoluted one at that) or the crank/bearings or all of the above.
But good luck and keep us posted!
 Smiley
Joe Fieroshop
« Reply #2 on: February 01, 2005, 08:13:44 pm »
Show us some pic's  Afro, sounds like youe car is going to rock Afro keep us posted and hope to see it one day. Great job.
Joe
« Reply #3 on: February 07, 2005, 11:26:05 pm »
still very interested in the modified cams you have.
Any update of more info on that???
LMK, pls!!!
