April 19, 2025, 04:17:51 am
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: 1 inch lowering ball joints « previous next »
Author Topic: 1 inch lowering ball joints  (Read 3441 times)
« on: February 28, 2005, 12:26:18 pm »
Just purchased them from Rodneys.
http://www.fiero.nl/forum/Forum2/HTML/058096.html
He recomends welding them in.
Don't think that Dan has a portable welder at his garage so if any of you members have a 110 volt buzzbox that I can borrow for the long weekend in March let me know (can supply "damage deposit" if required).
« Reply #1 on: February 28, 2005, 12:52:52 pm »
I could lend you a 600v 3 phase?
But honestly because this is a suspension component you are going to want a certified welder to do that for you.  That's my strong recommendation.  Should cost you about $15 to weld those in, as long as you have it all prepared for him/her.
« Reply #2 on: February 28, 2005, 03:59:04 pm »
Personally, The thought of welding on any suspension part is dicey, but it is only 4 spot welds.  Dan -  you have someone lined up to do a bit of spot welding if we can send out the part to Bellville??
« Last Edit: February 28, 2005, 04:00:53 pm by GoFast88 » Logged
« Reply #3 on: March 21, 2005, 01:19:33 pm »
Anyone have a ball joint remover I can borrow for the weekend? I will check Canadian Tire, but I doubt it.
http://www.overstock.com/cgi-bin/d2.cgi?PAGE=PRODUCT&PROD_ID=1132102&cid=52956&fp=F
« Reply #4 on: March 23, 2005, 09:03:17 am »
Someone must have a clamp style ball remover in Fiero land  Huh
« Reply #5 on: March 23, 2005, 09:15:22 am »
Not here...  whenever I need one changed I pull the control arm and take it to a local shop.  A whole $20 to press out the old & press in the new.
You could try CTC's loan-a-tool program, but I don't remember seeing a ball joint press the last time I looked.
« Reply #6 on: March 23, 2005, 01:05:02 pm »
All they have is the fork type. I have "reserved" it but I can see that it is going to be a pain the the a** to use instead of the clamp type.
« Reply #7 on: March 23, 2005, 02:54:31 pm »
I am just curious as to whose ass is going to feel the pain. Dan
« Reply #8 on: March 24, 2005, 11:15:31 am »
If my suspicion is correct, it'll be Brian's ass that feels it.  "Fork type" sounds like a pickle-fork style ball joint separator, which ain't gonna do diddly to remove the ball joint from the control arm!
Brian if the tool you have on reserve looks like this... ...it is not the thing you need to remove the ball joint from the LCA.
« Reply #9 on: March 24, 2005, 11:52:33 am »
Brian you have a PM
