January 11, 2025, 05:02:10 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Our locator beacon « previous next »
Pages: [1] 2 Go Down Print
Author Topic: Our locator beacon  (Read 3134 times)
Kitten
« on: April 05, 2005, 09:20:22 am »
Well I've thought about this for a while and after the last meeting ending up with two groups in the same restaurant we need a locator beacon when we are in a restaurant...
So the suggestions so far are:
Something with Thingie
A fiero flag
Any more suggestions?
« Reply #1 on: April 05, 2005, 09:24:50 am »
No one will know what the thingie is.  Tongue
A Fiero flag or just a sign with the club name would do fine.  Want one done?
Can do a small folding stand in a container as well..
« Reply #2 on: April 05, 2005, 10:04:18 am »
Huh
Kitten
« Reply #3 on: April 05, 2005, 10:41:19 am »
works for me  Smiley
« Reply #4 on: April 05, 2005, 01:26:53 pm »
something like this
« Reply #5 on: April 05, 2005, 02:16:05 pm »
Aaron you're having far too much fun with that CAD software.  Wink
That should work though.  I may even have something lying around which can be turned in to a base.  Just need the triangle thingie to mount on top of it.
« Reply #6 on: April 05, 2005, 04:21:04 pm »
It takes me less time to draw it out than it would take to explain it.  I drew that in about 30 seconds, then about 20 seconds in paint and voila.
A candle base might be good but you want the stem to be about 29" to the bottom of the flag or it might be a pain to see through.
« Reply #7 on: April 05, 2005, 06:07:55 pm »
...or just make sure that everyone slouches in their chairs.  Wink
Unfortunately what I had in mind a) probably isn't anywhere near tall enough and b) isn't where I thought it was.   Sad
« Reply #8 on: April 05, 2005, 06:39:30 pm »
Huh
yeah
hang that on the back of a chair facing the door so everyone sees it!
nawwwwww
that sounds too easy
« Reply #9 on: April 05, 2005, 06:39:57 pm »
[hint]  Small ABS tube for storage, wood disc for base, extendable car antenna for height and sign for the top.[/hint]
« Reply #10 on: April 05, 2005, 06:42:17 pm »
Actually maybe spring for pins saying 'ask for the Fiero guys'  for the waitresses to wear on their.... err uniform.
« Reply #11 on: April 05, 2005, 06:44:20 pm »
how about an 8 1/2x11 with a bright (attention grabbing) pic of a fiero and an arrow pointing (ie left or right) to the table we are at.........
make up a couple of these in advance (one left, one right, one straight ahead) and stick one up just inside the door.
the price is right.....
« Reply #12 on: April 06, 2005, 07:43:39 am »
The Fierobuzz logo looks good on a 8 1/2 x 11" sheet of paper and is disposable.
« Reply #13 on: April 06, 2005, 11:28:58 am »
I can make the base out of stuff in the scrap bin.
« Reply #14 on: April 07, 2005, 11:11:30 am »
Make it so.   Afro
Pages: [1] 2 Go Up Print
