January 15, 2025, 12:14:00 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: code 33 « previous next »
Author Topic: code 33  (Read 1460 times)
WillEV
« on: May 02, 2005, 11:56:41 pm »
ok I haven't ran my car for about 2yrs, when I put it away then the idel was slightly high. Well I put a new battery in it today and it was reving all the way up to 4000 rm. Sad
I checked the computer and it gave me a code 33 - MAP sensor or a vacum leak. I'm thinking vacum leak rather than the sensor.
What do you guys think, has anyone have this problem before?
Will
« Reply #1 on: May 03, 2005, 09:26:10 am »
Even if you do have a problem with your map sensor you still also have a vacuum leak.  I'm not sure how else you could have an idle that high?  Also check the positioning of the throttle plate and IAC (still a vacumm issue).
Joe Fieroshop
« Reply #2 on: May 03, 2005, 11:15:47 am »
Will, do you have a V6? if so check the EGR pipe, sometimes they'll cause a high rev. vacum leak. One way to find out is by spraying cab. cleaner along the tube, especially at each end ( plenum base and EGR addap. base)
Hope I could have been some help to you, good luck.
Joe
« Reply #3 on: May 04, 2005, 12:11:25 pm »
Kill the vacuum leak, then worry about the MAP sensor if it's still blinking that pretty orange light at you.
Wouldn't surprise me if you had a failing vacuum line when you put the car away, and dry rot has done the rest of the work over the last two years of storage.
