January 17, 2025, 06:40:31 pm
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: PILE of 85 parts; $100 for package. « previous next »
Author Topic: PILE of 85 parts; $100 for package.  (Read 1659 times)
« on: May 06, 2005, 06:11:16 pm »
I have to get rid of at least SOME of this stuff so I am going to sell a whole PILE of parts as a package; $100 for the whole shot. I don't want to keep trying to deal with a whole bunch of little items one at a time; they gotta go.
Includes (but not necessarily limited to):
radiator; good condition from a running car (mine);
alternator - (the lower output one - (about 63?) amps;
rear struts both sides;
rear springs; both sides;
BRAKES:
rear brake calipers both sides w/o the ebrake brackets - worked fine when removed;
front calipers both sides; (1 - drivers side I think) is seized; other was fine when removed;
some brake pads; used; maybe usable maybe not;
one front rotor; usable condition;
master cylinder - worked fine when removed; no reservoir (swap yours on);
unidentified brake dust shields; I have 4 but not sure they are all fiero ( Huh)
front (pretty sure) caliper mounting brackets;
special funny brake caliper mounting bolts;
MISC:
various front wheel bearings; inner and outer;
2 rear wheel bearings; I believe at least one is in good cond; maybe both;
rear (engine) coil/distributor cooling fan with ductwork ('tubing') - can test but worked fine;
US (mph version) speedo cluster; was going to use if for experiment/testing;
one rear 'knuckle' - prob have the other but need to dig a bit more...... Roll Eyes
Gotta get it out of the way. There is a lot of misc little stuff too; I have an unidentified engine sensor;
another item; I think it is an EGR switch/controller of some sort; has both elect and vacuum to/from it;
whatever else I can dig up; I'll throw in too.
contact me by PM or email at mechdes3.4@sympatico.ca
I am pretty flexible in what time you can come by to get it or have a look.
thanks!!
EDIT May 10th to add:
an engine sensor (forget which this is) and a fiero spare tire/wheel including the formed "tub" that it sits in if someone needs one for some reason.  Also some engine/trans mounts.
I will try to get everything into a nice 'group' photo - maybe today - in case a pic helps.
« Last Edit: May 10, 2005, 07:22:49 am by fiero308 » Logged
coolman_890
« Reply #1 on: May 10, 2005, 07:03:53 pm »
i will take it. call me 227-1851
« Reply #2 on: May 10, 2005, 10:48:02 pm »
and they're........GONNNNNNNE.
thanks all for looking
now I can see my garage floor!  ok. In places, anyway.   Roll Eyes
