April 26, 2025, 07:45:26 am
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: Long bolts for Upper Control arms; 84-87 « previous next »
Author Topic: Long bolts for Upper Control arms; 84-87  (Read 1678 times)
« on: May 17, 2005, 08:00:18 am »
I ended up with these because ..... well I sort of misplaced the ones I bought over a yr ago. If you are planning on doing work on your control arms and they have not been off for a long time you may end up cutting out the stock bolts.
These are slightly longer than stock; about 1/2" or so but they DO fit. They are Allen (socket) head. They are the correct diameter (12mm; NOT 1/2"!!) and are STRONGER than stock/required. New (yuch) they are over $35 EACH at the fastener warehouse (whatever it is called) in Bells Corners. Phone them and check it out if you want to verify.
THEY ARE NO LONGER AVAILABLE FROM GM; since sometime in the past yr or two.  I don't need them (geez, not again.... Embarrassed) and will sell them for $30 for the pair. Brand new, never used.
Can send pix if needed. LMK
email at  mechdes3.4@sympatico.ca
or PM me.
THANKS!
g
