April 26, 2025, 02:00:29 pm
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: Need a pass side headlight motor « previous next »
Author Topic: Need a pass side headlight motor  (Read 2866 times)
sparkytoo
« on: May 27, 2005, 01:37:39 am »
I need an early pass side headlight motor,can have a bad gear as I have a rebuild kit but need a motor.
« Reply #1 on: May 27, 2005, 12:34:06 pm »
  Where are you located?, there is a silver Fiero in my neck of the woods with a stuck up headlight. I have some motors I took out of the landmark I have in my driveway if you are close. All I have to do is find them.
sparkytoo
« Reply #2 on: June 01, 2005, 08:11:52 pm »
Anyone? someone must have a dead motor they want to get rid of,also I'm on the west coast so it would have to be mailed.
« Reply #3 on: June 01, 2005, 09:00:41 pm »
 Have you checked with these fine folks? url=http://www.westcoastfieros.com]www.westcoastfieros.com[/url] They might be able to help you out a bit more easily as they are in your area.   Kevin
sparkytoo
« Reply #4 on: June 01, 2005, 09:26:33 pm »
Its pretty easy to mail a headlight motor???
« Reply #5 on: June 02, 2005, 08:00:14 am »
At Canadian Postal rates, as compared to the US, you might be better off buying new in the states.
« Reply #6 on: June 02, 2005, 08:26:41 am »
Not really.  I priced out shipping the motor only to Alberta last year, and it was under $10.
Once you separate the motor from the bucket etc., it's not much bigger than three VHS tapes stacked together & weighs only slightly more.
sparkytoo--if I can figure out where it went, I may have a motor for you.  The nylon gear is FUBAR, but as far as I know it is otherwise ok.  If I can find it, it's yours for the cost of shipping.  I'll have a look this weekend and let you know...
sparkytoo
« Reply #7 on: June 04, 2005, 02:32:17 am »
thank you thats very generous and much appreciated.
« Reply #8 on: June 04, 2005, 06:56:57 am »
Found it... photos attached.
Like I said earlier, other than the gear it is probably ok, although I have never actually tested it.  At minimum it appears to need the old chunked-up grease cleaned out and new grease applied.
If you like what you see, send me your snail mail address via PM and I'll get a shipping guesstimate from Canada Post.
« Last Edit: June 04, 2005, 07:02:47 am by dguy » Logged
