April 15, 2025, 09:00:09 am
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: Making Steel Cradle Bushings (or hope to) « previous next »
Author Topic: Making Steel Cradle Bushings (or hope to)  (Read 3129 times)
« on: June 08, 2005, 08:13:08 am »
well the title says it all, really.
I understand that the 88 uses solid mounting and I know that every front engine, rear drive car I have ever seen does NOT have the equivalent 'double rubber' mounting effect that our rear cradle has (cradle is rubber mounted then OFF THAT is the control arms; FURTHER rubber mounted....)
So all that being said I have found in my build up that I seem to be 'short' some steel caps or plates that go above/below the stock rubber or poly bushings (I have a set of poly..... Roll Eyes ) so.........
I am going to see how hard it might be to make a set of steel bushings. I also know that the hot rod and racing types prefer steel .....even over aluminum. (Surprise.)
Steel simply lasts longer; like indefinitely, I guess. So after laying in an assortment of steel hole saws, (whew; the big ones - ie 3 1/2" dia- are not cheap... Sad ) I am going to start fiddling with this idea.
I have been asked by a local member if I would be interested in making an extra set and I am saying yes at the moment but beyond that I am going to have to see. Hole saws don't last forever and one bad moment/slip can break one easily so I am going to have to take that cost into acct.
I am using or thinking of using hole saws to make my circular plates simply because I am not will to spend my time cutting them on a bandsaw etc and then grinding them round; a very slow and not as exact process. Cheap with my time these days.  Shocked
So once I get people off my back at work here I will get going on this. Oh, by the way, Darrell Morses pieces seem to be nice; (aluminum bushing set) but I am figuring that they are just about $200 Cdn once they arrive in my hot little hands. $100US with exchange, shipping, customs, duties and taxes. So that is my 'option' and comparison.
More in the next couple of days. This IS holding up my build thread so I have to get going on it.
« Reply #1 on: June 08, 2005, 12:50:16 pm »
Two things:
One; I agree with part of the steel argument.  I prefer steel (read stainless) A-arms and such but prefer aluminum bushings with a stainless insert.
Two; you can use the lath here at my work if you can get out when I'm here after work or on the weekend.  It should make for much better accuracy.
« Reply #2 on: June 08, 2005, 12:54:33 pm »
thanks for the offer Aaron but I have an idea in mind about making them hollow; or at least trying that route.   Roll Eyes
I have no prob with mild steel - everything else in the car is steel (and SOME of it is scary-lousy quality!!) and so this wouldn't be a weakest link in any way. I'll see how it goes; it is something I was thinking of doing anyway. Just figured it would be later rather than sooner.
Once I figure out a reasonably quick 'manufacturing method' I'll start the thread; but right now I have people starting to scream so I better keep them happy..... Wink
« Reply #3 on: June 09, 2005, 12:07:36 pm »
well things are on hold on this for the moment; I was very wishfully assuming that I would just whip thru this and get on with my engine swap etc etc but I am too impatient at the moment to wait and go thru this. So.........
since I already have a set of poly cradle bushings I am going to get the steel caps I need and just do it that way in an effort to keep moving ahead with the overall project.
I DO plan on doing the steel bushings, just it will have to wait a bit is all. I'll revive this thread or start another when I do.
g
« Reply #4 on: October 11, 2005, 12:10:58 pm »
Just in case you haven't seen it, and for when you get back to working on solid mounting the pre-88 cradle...
Ninth post in on this PFF thread shows a custom cradle which appears to be meant to solid mount to the pre-88 chassis.  It may be feasible to do something similar with a stock cradle.   Undecided
