This is the blaster design, Like NOTHING you have ever used before, Works on HIGH and LOW pressure from your compressor, Its not a POT, CUP or even a SIPHON blaster..
I was sick of clogging lines so designed my own and now own the patent!
I cant build everyone a unit (yet) So I sell the plans online all day for only $10 bucks..
You can see it here:
https://www.ammoman.com/sandblaster/Let me drop some updated pics here of my Fiero:
Sitting in position awaiting plates to hold the stretch, As you can see its already aligned, spot-welded and holding its own weight because of the 1" x 1" extensions I made to go inside the frame rails..
3/16ths plate on the surface connecting the old clip to the new one, Multiple holes drilled for plug-welds that will make the two become ONE..
Plug-welds now done and ground smooth on the drivers side...
Last a shot of zinc primer then its time for the other side and the inside plates...
Passengers side plug-welds just completed...
New forward cradle mounts and the internal plates being designed...
Regards
Rob
