January 11, 2025, 06:50:42 pm
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: Clutch Line Needed « previous next »
Author Topic: Clutch Line Needed  (Read 2357 times)
34FieroGT
This, is my BOOMSTICK!!!
« on: August 12, 2005, 08:21:57 am »
I am in need of a short section of clutch line, specifically from the master cylinder to just before where the line goes through the floor in the front compartment.  Doesn't need to be perfect, but I do require the nut for the master as well.  Hope this is clear enough.  If not, I can take pics.  Thanks!
tyler...
« Reply #1 on: August 12, 2005, 10:21:36 am »
Hey look another person who should have taken a better look in my storage sheds, have a complete line in good shape off an 84 I stripped. Dan
34FieroGT
« Reply #2 on: August 12, 2005, 11:13:05 am »
Will the complete line fit an '88?  I need this for my formula...
tyler...
« Reply #3 on: August 12, 2005, 12:18:21 pm »
Yep, it'll fit.  The end at the m/c will need to be bent slightly to meet the m/c's port, but that's the only "complication."
« Last Edit: August 12, 2005, 01:47:54 pm by dguy » Logged
« Reply #4 on: August 12, 2005, 01:13:22 pm »
Run new ones, bend them yourself.
34FieroGT
« Reply #5 on: August 14, 2005, 04:40:11 pm »
I have no problem bending up new lines myself, but I'm still going to need a new nut that screws the line into the master.  The previous owner really mangled this one up.
tyler...
« Reply #6 on: August 15, 2005, 09:38:26 am »
Make sure that the line going into the slave actually reaches all the way in and will tighten on.  I found that when I put mine together it didn’t fit right (would not tighten up all the way).  I had to take it back apart and add an extra spacer between the bubble flair and the nut to get the line to reach the bottom of the hole.  Apparently a lot of people have problems but don’t put 2 and 2 together, therefore end up with a leak they can’t fix.
You should be able to get a replacement nut a UAP, but make sure it’s long enough.  Or grab one from someone here.
