January 11, 2025, 06:52:36 pm
Parts
Clutch Line Needed
Topic: Clutch Line Needed (Read 2359 times)
34FieroGT
This, is my BOOMSTICK!!!
Clutch Line Needed
August 12, 2005, 08:21:57 am »
I am in need of a short section of clutch line, specifically from the master cylinder to just before where the line goes through the floor in the front compartment. Doesn't need to be perfect, but I do require the nut for the master as well. Hope this is clear enough. If not, I can take pics. Thanks!
tyler...
Re: Clutch Line Needed
August 12, 2005, 10:21:36 am »
Hey look another person who should have taken a better look in my storage sheds, have a complete line in good shape off an 84 I stripped. Dan
34FieroGT
August 12, 2005, 11:13:05 am »
Will the complete line fit an '88? I need this for my formula...
tyler...
August 12, 2005, 12:18:21 pm »
Yep, it'll fit. The end at the m/c will need to be bent slightly to meet the m/c's port, but that's the only "complication."
Last Edit: August 12, 2005, 01:47:54 pm by dguy
August 12, 2005, 01:13:22 pm »
Run new ones, bend them yourself.
34FieroGT
August 14, 2005, 04:40:11 pm »
I have no problem bending up new lines myself, but I'm still going to need a new nut that screws the line into the master. The previous owner really mangled this one up.
tyler...
August 15, 2005, 09:38:26 am »
Make sure that the line going into the slave actually reaches all the way in and will tighten on. I found that when I put mine together it didn’t fit right (would not tighten up all the way). I had to take it back apart and add an extra spacer between the bubble flair and the nut to get the line to reach the bottom of the hole. Apparently a lot of people have problems but don’t put 2 and 2 together, therefore end up with a leak they can’t fix.
You should be able to get a replacement nut a UAP, but make sure it’s long enough. Or grab one from someone here.
Parts
Clutch Line Needed
