April 17, 2025, 09:54:40 pm
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: Antennas « previous next »
Author Topic: Antennas  (Read 3545 times)
MacPhail
« on: November 09, 2005, 03:28:32 pm »
One thing I hate about cars:  Antennas.  My Honda Element has a nice little stubby on the room and I see other foreign cars with the same.
What do Fiero owners do to get rid of the darn thing.  It's the tallest feature on the car and not really one I feel like showing off.   Cheesy
« Reply #1 on: November 09, 2005, 05:14:14 pm »
shave it.
It fits nicely under the fender it sticks up out of.  People pull off the fender and lay it down pointing forward.  I think they just re-mount the existing bracket.
« Reply #2 on: November 10, 2005, 08:13:59 am »
Another alternative...
I used a generic antenna cable extension combined with the cable from the OEM antenna, and ran a line up in to the roof skin.
The cable runs under the dash, and up the right hand side a-pillar under the trim panel.  The cable's shield is grounded to the frame somewhere above the passenger seat; the remainder of the cable run has had the shielding removed (but the core insulator left intact) and looped around the rear of the sunroof hole between the space frame and the roof skin.
Works nicely; should be do-able in sunroof'd cars as well (mine isn't) but may require loosening of the roof skin studs in order to get the cable between the skin's sunroof frame and the space frame.   Undecided
Got photos at home, somewhere.  Will try to remember to dig 'em up & post.
« Reply #3 on: November 10, 2005, 08:47:38 am »
A couple af damm good ideas! Too bad I didn't think about those alternatives BEFORE I got the car painted.  Cry  A chrome button may be the only option for that hole left behind.
MacPhail
« Reply #4 on: November 10, 2005, 09:03:41 am »
I was wondering what one would do with the hole if there weren't any plans on repainting the car.
« Reply #5 on: November 10, 2005, 10:37:44 am »
Paint the button to match, it will look much better.  If you can't paint it to match, use black.
« Reply #6 on: November 10, 2005, 10:46:38 am »
Got this from PFF
« Reply #7 on: November 10, 2005, 12:37:24 pm »
shave it.
Dan or Don. Can you confirm that the bracket in the pic is the original stock bracket, and not an aftermarket one??
« Reply #8 on: November 11, 2005, 08:37:50 am »
OEM.
As promised, a photo of my method is attached.
The photo is looking up from the driver's side, at the passenger side a-pillar & door frame.  Bad lighting and ghosts from assembling a multi-shot panorama aside, you should be able to make out the cable snaking up the pillar.  The yellow smudge where the cable changes from black to white is a ring terminal grounding the cable's shield to the frame.  The white section is what the antenna cable looks like once the outer insulation & shield has been stripped.
« Last Edit: November 11, 2005, 08:41:08 am by dguy » Logged
