April 06, 2025, 10:48:32 pm
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: Side Vents « previous next »
Author Topic: Side Vents  (Read 3516 times)
« on: April 11, 2006, 01:45:30 pm »
Has anybody ever vented the front sides of their Fiero, similar in fashion to those found on BMW's?
http://www.bmwmregistry.com/faq/M_roadster_sidegills.jpg
Perhaps they would not be as effective at cooling as a roof vent.  Thoughts?
« Reply #1 on: April 11, 2006, 01:52:44 pm »
Normal Fiero practice is to make a similar vent in the lower hood.
The BMW location would just vent your frunk.  Evil
« Reply #2 on: April 12, 2006, 01:25:27 pm »
Why be "normal"?    Afro
The "frunk" contains the same heat that the lower hood vents deal with...or so I would assume having never actually sat in the frunk to see for myself (I'm not a Bandido).  :p  It may not do the job as effectively as the lower hood vents, but it may work nonetheless...right?
« Reply #3 on: April 12, 2006, 02:29:01 pm »
Trust me, Not Buzz is not normal as evidenced by the chromatics of his engine bay.   Tongue
Not really.  Traditional hood vents are placed in the area between the frunk and the radiator, allowing some of the air which has passed through the radiator to exit upward over the hood instead of forcing it all down and under the chassis.
The frunk OTOH, is an odd-shaped box which is loosely sealed from the elements.  Hot air from the radiator does not pass through it.  Venting the frunk may lessen the chance of your spare tire and brake master cylinder suffering from oxygen starvation, but that's about it.  Smiley
If your purpose for adding vents to the frunk is for heat dissipation, I suspect that you'll be disappointed with the result.
« Reply #4 on: April 12, 2006, 02:36:43 pm »
Ok...so the side vents won't work.
But what you are saying is that venting the frunk will be beneficial if I wanted to transport really tiny people in it?   Cheesy
« Reply #5 on: April 12, 2006, 04:11:52 pm »
Buzz...care to share some pics of the chrome?    Smiley
