April 15, 2025, 08:18:57 am
Ottawa Fiero Club Forum  |  General  |  Mods  |  Topic: Belt Run Opinions Wanted « previous next »
Author Topic: Belt Run Opinions Wanted  (Read 3599 times)
« on: April 12, 2006, 06:54:41 pm »
Choice 1 (Easy)
Bear in mind that the belt in the pic is too long and is just slightly tight as the alternator is just sitting in place.
Do you think that the run from supercharger to alt to crank pulley would be okay.  Will it be tight enough for the s/c pulley not to slip and also not too long to cause the belt to be thrown off.
« Last Edit: April 12, 2006, 06:56:49 pm by not buzz till its done » Logged
« Reply #1 on: April 12, 2006, 06:56:16 pm »
Choice 2
Same run but an extra idler added to that long run.  Necessary or just too much concern on my part?
« Reply #2 on: April 12, 2006, 07:00:30 pm »
Would go with run #2 if it was me but then again if it was me I would toss the series I for a better series II but thats just me. HEE Dan
« Reply #3 on: April 12, 2006, 07:02:38 pm »
I'm not upset.....you did say that you agreed with me in the other thread  Kiss
PBJ
« Reply #4 on: April 12, 2006, 11:02:56 pm »
Definately number two, the more belt wrap area on the pulley the better.  Also series one or two, either will make a fiero haul and bring a grin to your face.
Pete
« Reply #5 on: April 13, 2006, 08:06:32 am »
#2!
Put it this way...  more wrap now while the engine's out is pain-free, and lessens the chances of it slipping.  Less wrap now may mean you have to re-do it.
« Last Edit: April 13, 2006, 08:08:07 am by dguy » Logged
Rob
« Reply #6 on: April 13, 2006, 09:00:44 pm »
ive been thinking of doing something similar with a seriies 2 but would need to bring the water pump and alternator pulles out, that would be okay for the alternator, but I think it would put to much stress on the waterpump bearings for my likeing!
« Reply #7 on: April 14, 2006, 11:08:05 am »
hi Gary
I think you have lots of belt wrap (on both top and bottom pulleys) in Option 1; it is more than 1/2 the pulley and I think you are only gaining another degree or two with the extra idler pulley. The tension in the belt will be the same all the way around so you don't gain/lose anything there. It LOOKS like it is missing something, yes, but I think this is where you have to 'go with the numbers'.... so to speak. What do you hope to gain or what is it you are trying to avoid with the extra pulley?
Look at how LITTLE wrap you have on some of them; and that is doing the job.
« Reply #8 on: April 14, 2006, 11:38:59 am »
Graeme, the s/c pulley is prone to slip if it doesn't have a really good tight belt contact as far around as possible.  I think both of these may be slightly less than the stock 2 belt setup.  The w/p doesn't need much as it is pretty low resistance.
I have to make a small 2 or 3 prong fitting for the new idler.  That's the only work I'd save and maybe only temporarily at that.  I think I'll redo the coil packs in the stock location.  That means I can extend the bolts a bit and have the mount run there.
With the crossover and the manifold wrapped I don't think heat will be an issue with the coils.  The small space saving of sticking them in the old battery spot is not worth the effort right now.   Azn
