November 01, 2024, 04:19:53 am
Ottawa Fiero Club Forum  |  General  |  General Chat  |  Topic: Hey Don « previous next »
Author Topic: Hey Don  (Read 1320 times)
« on: May 18, 2006, 04:55:51 pm »
Was fooling around trying to come up with a temporary front cradle bushing and came across a couple of old Astro van tranny mounts. Took the mounts apart for the sleeves and figured if welded to the cradle they would work for a solid front mount. See attached photo's to see what you think. Dan
« Reply #1 on: May 18, 2006, 05:05:16 pm »
All Martin White did to solid mount was to weld a big washer to the ends.  Worked fine.
That mount would be a lot better as it has an integral tube for the bolt to run in.  Just remember to put a long rod thru the two sides so that the cradle is lined up when they get welded to it.
« Reply #2 on: May 19, 2006, 08:28:26 am »
Those are my thoughts pretty much exactly.  Smiley
I'm using a set of Darrel Morse's aluminuminum bushings for the swap in to my car, but I'll have to remember this trick for any future work.
« Reply #3 on: May 19, 2006, 08:35:22 pm »
The 88's are solid mounted and I don't hear lots of complaints.  Time to make up a small jig on your spare cradle and start making a few sets.  Afro
