September 21, 2024, 04:24:48 am
Ottawa Fiero Club Forum  |  Buy/Sell/Trade  |  Parts  |  Topic: LF: 2.8 Throttle body « previous next »
Author Topic: LF: 2.8 Throttle body  (Read 3041 times)
« on: June 09, 2006, 12:29:31 pm »
Seems that mine now has about 1.5cm of a broken tap jammed deep inside one of the mounting holes for the TPS.   Angry
Drilling a hardened steel tap out of an aluminum throttle body without a press is...    Roll Eyes
« Reply #1 on: June 09, 2006, 12:33:59 pm »
 This sounds like a good excuse to buy a new power tool.
« Reply #2 on: June 09, 2006, 12:45:26 pm »
Trust me if I could figure out where to put a drill press, I'd have bought one a year or two ago.  Smiley
« Reply #3 on: June 09, 2006, 01:57:58 pm »
I'll look in the back!  I know I did, but may have given it away.
« Reply #4 on: June 09, 2006, 03:04:31 pm »
Just stick that 3800SC in there and be done with that old useless 2.8. If not I have at least one or two out in the garage. Dan
34FieroGT
This, is my BOOMSTICK!!!
« Reply #5 on: June 09, 2006, 04:22:37 pm »
Don,
I've got a couple of spares as well if you wanted one.  Let me know.
tyler...
« Reply #6 on: June 09, 2006, 09:26:48 pm »
Where you using lube when you broke that tap?
« Reply #7 on: June 10, 2006, 02:02:46 pm »
Yup, always do.  It felt like it caught on something just before breaking, though I have no idea what.  Not that it would take much force; the tap was for a 4mm hole.
I may have a handle on things now though.  I was able to drill out the area around the tap without wrecking the TPS's mounting post and extract the little beast.  I'm filling the crater with JB weld at the moment and inserting a heli-coil for good measure.  I don't see why it won't do the trick; the only force it has to withstand is that of the TPS's return spring.
In any case if it fails, I'm sure someone above will hear from me.  Smiley  Thanks guys!
« Reply #8 on: June 11, 2006, 09:18:19 pm »
Those little suckers are a pain.
I have some tips but I won't post these secrets, you'll have to wait for a face to face (or call).
