October 31, 2024, 11:28:47 pm
Foamy prestone
Topic: Foamy prestone (Read 1713 times)
Foamy prestone
July 11, 2006, 05:50:31 pm »
Got this piece of crap 2.8 back in and running unfortunately it over heats with a thermostat in so I figured air lock and removed thermostat and ran for a while, took for a few short drives then let cool to instal a t-stat. well took off the cap and foam spewed out now that doesn't look very good I am thinking head gasket or some thing any ideas nicer than that to deal with. Dan
Re: Foamy prestone
July 12, 2006, 08:14:56 am »
Any "chocolate milk" in the bottom of the oil pan and/or coolant being pushed past the radiator cap prematurely?
Re: Foamy prestone
July 12, 2006, 10:09:20 am »
Oil is fine and pan is clean and its not losing prestone its just getting foamy and will over heat with a t-stat installed. Dan
Re: Foamy prestone
July 12, 2006, 10:53:41 am »
Have you drilled the 'stat? I always put a couple of small holes in to allow any air to travel thru the system. Can you see the water moving in the rad? I wonder if the w/pump is just spinning enough to froth the coolant and not to circulate it properly.
Re: Foamy prestone
July 12, 2006, 11:54:51 am »
Quote from: not buzz till its done on July 12, 2006, 10:53:41 am
That was my next thought. Slipping impeller or other pumping problem which can barely move coolant with the t-stat removed, and can't do squat with the t-stat in place.
Dan is this the same car you just did the timing chain on?
Re: Foamy prestone
July 12, 2006, 06:36:08 pm »
Yep same car looks like this one hasn't seen regular maintenance for a long time. Dan
Foamy prestone
